[mapserver-dev] mapserver.gis.umn.edu
Perry Nacionales
pnaciona at gmail.com
Tue Jul 26 06:22:24 PDT 2016
I think you're right, Daniel. I forwarded jeff's message to Trent Erickson
just in case.
-Perry
On Jul 26, 2016 8:18 AM, "Daniel Morissette" <dmorissette at mapgears.com>
wrote:
> I suspect the issue may be a missing "ServerAlias mapserver.gis.umn.edu"
> in the mapserver.org VirtualHost on the OSGeo server at 140.211.15.3 (I
> do not have access to verify)
> i.e. the DNS entry for mapserver.gis.umn.edu already points correctly to
> the mapserver.org server:
> ;; ANSWER SECTION:
> mapserver.gis.umn.edu. 17999 IN CNAME mapserver.org.
> mapserver.org. 3599 IN A 140.211.15.3
> And the 140.211.15.3 server responds with the Geotools virutalhost
> contents for any domain that is not recognized, or if you access the server
> directly by IP: http://140.211.15.3/
> It may also be a good idea to set the default VirtualHost for
> http://140.211.15.3/ to be a redirect to osgeo.org, or to anything except
> falling back on one of the project-specific VirtualHost as is currently the
> case with the fallback on the geotools.org virtualhost.
> Daniel
> On 2016-07-26 8:55 AM, Jeff McKenna wrote:
>> Hello everyone,
>> This morning I noticed that the old url (http://mapserver.gis.umn.edu/)
>> actually redirects to the GeoTools main page; this is startling, as
>> there are literally thousands of old pages & links out there on the
>> internet still pointing to http://mapserver.gis.umn.edu/ (indeed this
>> explains why Google lists GeoTools so high up when you search for
>> MapServer)
>> Could someone from the UMN gang tackle this right away? Please make
>> sure the old site points to http://mapserver.org/ Thanks,
>> -jeff
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
> Daniel Morissette
> http://www.mapgears.com/
> T: +1 418-696-5056 #201
> http://evouala.com/ - Location Intelligence Made Easy
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20160726/e126b419/attachment.html>
