[mapserver-dev] getExpressionString issue
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu Mar 24 08:30:05 PDT 2016
I'm not sure. I know that for PHPmapscript there is no getClassByName
function (it was filed as a ticket back in 2002 ha). I'm also not aware
of any recent changes in MapServer that fixed your issue. Maybe others
have ideas. I just cannot reproduce this with MapServer 7.0.1
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2016-03-24 11:56 AM, Donald wrote:
> I'm using MapServer version 6.2.0, in Ubuntu. I pasted a piece of the
> code that I'm using that is a little different from the one you
> presented but it's working for all expressions that don't have dots in
> it. Do you think that it could be a problem related to MapServer version ?
> public static function _zoomtoclass ( $_map, $_classname ){
> $class = $_map->getClassByName($_classname);
> $layer = $class->getLayer();
> if ($class->isPostgisType()){
> $connection = $class->getConnection();
> $metadatatable = $class->getMetadataDataTable();
> if ($metadatatable != ''){
> $table = $metadatatable;
> } else {
> $table = $class->getDataTable();
> $postis_table_obj = new ngPostgisLayer($connection, $table);
> $classitem = $class->getClassitem();
> $expression = $class->getExpressionString();
> 2016-03-24 14:06 GMT+00:00 Jeff McKenna <jmckenna at gatewaygeomatics.com
> <mailto:jmckenna at gatewaygeomatics.com>>:
> Hi David,
> I have tested this locally using a string field that has values of
> "0.5 - 1.0" the same as yours, and have setup a mapfile layer with
> an expression of: EXPRESSION "0.5 - 1.0" I am able to correctly
> echo that expression through PHPmapscript's getExpressionString()
> such as:
> // open existing mapfile
> $oMap = ms_newMapObj("./getexpression.map");
> //get layer
> $oLayer = $oMap->getLayerByName("test");
> //get class
> $oClass = $oLayer->getClass(0);
> //get expression
> $expression = $oClass->getExpressionString();
> echo $expression;
> I am testing with MS4W 3.1.3 (MapServer 7.0.1).
> -jeff
> Jeff McKenna
> On 2016-03-24 8:23 AM, Donald wrote:
> Hello everyone,
> I have a mapfile with the folowing setup.
> CLASS
> NAME "a7127d96d561327f30ee0e4d3d3bb43e"
> EXPRESSION ('[reu]' = '0.5 - 1.0')
> STYLE
> COLOR 76 179 42
> OUTLINECOLOR 76 179 42
> SIZE 3
> END # STYLE
> TITLE "1525c/62c//0.5 - 1.0"
> END # CLASS
> Whenever I call the method
> /$class->getExpressionString() /I get a string "05 - 10" instead
> of "0.5
> - 1.0". What should I do to solve this issue ?
> Thanks,
> David
