[mapserver-dev] Performance issue with hatching with a pattern of a polygon
Stephen Woodbridge woodbri at swoodbridge.com
Mon Nov 14 08:11:45 PST 2016
Yeah, I also built 7.0.2 to check performance with that and it is
basically the same as 6.4.3 for this case.
One of the nice use cases for using hatch patterns, is that they allow
the under lying geometry to show through, which decouples the background
from the hatching, so for example if one has sand bars in the water you
can have the water, and apply a sandy colored dot pattern over it where
the sand bars are. Or for intermittent water areas you can put a blue
dot pattern over the land area, and for swamps I use a blue dot pattern
overlayed with tuffs of grass generated with a vector symbol. The
current system works very well, except for this performance corner case.
For the time being, I spread out my dots and made them larger to speed
things up a little. I don't like the resulting imagery as much and it is
still painfully slow, but a little faster than before.
I was ideally wondering if it might make sense to have a DOTS class like
HATCH that would take DX, DY, ANGLE, SIZE as attributes that would be
able to special case the rendering of DOTS a lot faster? I suspect, that
the issue is that implementation of PATTERNed HATCH is flexible but not
efficient for all cases. Where the PATTERN is longer it seems to run
faster, but a PATTERN 1 2 END is horribly slow when filling large areas.
-Steve W
On 11/14/2016 10:17 AM, lars.schylberg at blixtmail.se wrote:
> Hi,
> I just became curious since I haven't used hatch patterns that much.  So
> I made some examples myself.
> It is clear from my experiments that hatch patterns takes quite some
> time to render in the current implementation.
> My test is here:
> https://gist.github.com/LarsSchy/5236d172a7534275e2d1406ca2cca5c3
> mapserv -v
> MapServer version 7.0.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ
> SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=SVG_SYMBOLS
> SUPPORTS=RSVG SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
> SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
> SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR
> INPUT=GDAL INPUT=SHAPEFILE
> -map_debug 5
> msDrawMap(): rendering using outputformat named png (AGG/PNG).
> msDrawMap(): WMS/WFS set-up and query, 0.000s
> msDrawMap(): Layer 0 (Example 1), 0.002s
> msDrawMap(): Layer 1 (Example 2), 0.018s
> msDrawMap(): Layer 2 (Example 3), 0.011s
> msDrawMap(): Layer 3 (Example 4), 0.005s
> msDrawMap(): Layer 4 (Example 5), 0.001s
> msDrawMap(): Layer 5 (Example 6), 0.018s
> msDrawMap(): Layer 6 (Example 7), 0.013s
> msDrawMap(): Layer 7 (Example 8), 0.045s
> msDrawMap(): Layer 8 (Example 9), 0.000s
> msDrawMap(): Layer 9 (Example 10), 0.000s
> msDrawMap(): Layer 10 (Example 11), 0.000s
> msDrawMap(): Layer 11 (Example 12), 0.000s
> msDrawMap(): Drawing Label Cache, 0.003s
> msDrawMap() total time: 0.118s
> msSaveImage(polygon-examples-hatch.png) total time: 0.025s
> msFreeMap(): freeing map at 0x22d1340.
> A simple box filled with the hatch and PATTERN takes 18 ms to render in
> example 2.  Example 8 with a double hatch is 45 ms.
> The other patterns without hatch in example 9 - 12 are all less than 1 ms.
> Lars Schylberg
> -----Originalmeddelande-----
>> Från: "Stephen Woodbridge" <woodbri at swoodbridge.com
> <mailto:woodbri at swoodbridge.com>>
>> Till: mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>
>> Datum: 2016-11-13 16:47
>> Ämne: Re: [mapserver-dev] Performance issue with hatching with a
> mapserver-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
