[mapserver-dev] [gdal-dev] GML lat-lon coverages and interoperability
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Mon Apr 3 23:55:55 PDT 2017
Adding mapserver-dev to recipients in hope that Stephan Meissl notices and could share his opinion. Mapserver WCS 2.0.1 does not generate axisOrder.
-Jukka Rahkonen-
Lähettäjä: Even Rouault <even.rouault at spatialys.com>
Lähetetty: 3. huhtikuuta 2017 23:03
Vastaanottaja: gdal-dev at lists.osgeo.org
Kopio: Rahkonen Jukka (MML); Andrea Aime; geoserver-devel at lists.sourceforge.net
Aihe: Re: [gdal-dev] GML lat-lon coverages and interoperability
On lundi 3 avril 2017 13:19:18 CEST Rahkonen Jukka (MML) wrote:
> Great, first hit from Andrea. I am awaiting if Even strikes back.
I don't really have an opinion on this. I haven't read the relevant part of the GML or GMLCOV spec and I'm afraid I wouldn't understand it well. The GDAL GMLJP2 code just follows what the GMLJP2 spec and examples suggest, as well as data productions. Perhaps it is not "correct"...
> His
> creation (GDAL JP2OpenJPEG driver) writes out EPSG:4326 coverage into GML
> JP2 this way, without having gridFunction.
> <gml:FeatureCollection
> xmlns:gml="http://www.opengis.net/gml"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:schemaLocation="http://www.opengis.net/gml
> http://schemas.opengis.net/gml/3.1.1/profiles/gmlJP2Profile/1.0.0/gmlJP2Pro
> file.xsd">
<gml:boundedBy>
> <gml:Envelope srsName="urn:ogc:def:crs:EPSG::4326">
> <gml:lowerCorner>61.7282236395245 24.7248340978191</gml:lowerCorner>
> <gml:upperCorner>61.7838827490233 24.8422668729657</gml:upperCorner>
> </gml:Envelope>
> </gml:boundedBy>
> <gml:featureMember>
> <gml:FeatureCollection>
> <gml:featureMember>
> <gml:RectifiedGridCoverage dimension="2" gml:id="RGC0001">
> <gml:rectifiedGridDomain>
> <gml:RectifiedGrid dimension="2">
> <gml:limits>
> <gml:GridEnvelope>
> <gml:low>0 0</gml:low>
> <gml:high>15517 7354</gml:high>
> </gml:GridEnvelope>
> </gml:limits>
> <gml:axisName>x</gml:axisName>
> <gml:axisName>y</gml:axisName>
> <gml:origin>
> <gml:Point gml:id="P0001"
<gml:pos>61.7838789652633
> 24.7248378815791</gml:pos> </gml:Point>
> </gml:origin>
> <gml:offsetVector srsName="urn:ogc:def:crs:EPSG::4326">0
> 7.56751998624388e-006</gml:offsetVector>
<gml:offsetVector
> srsName="urn:ogc:def:crs:EPSG::4326">-7.56751998624388e-006
> 0</gml:offsetVector> </gml:RectifiedGrid>
> </gml:rectifiedGridDomain>
> <gml:rangeSet>
> <gml:File>
> <gml:rangeParameters/>
> <gml:fileName>gmljp2://codestream/0</gml:fileName>
> <gml:fileStructure>Record Interleaved</gml:fileStructure>
> </gml:File>
> </gml:rangeSet>
> </gml:RectifiedGridCoverage>
> </gml:featureMember>
> </gml:FeatureCollection>
> -Jukka-
> Lähettäjä: andrea.aime at gmail.com [mailto:andrea.aime at gmail.com] Puolesta
> Andrea Aime
Lähetetty: 3. huhtikuuta 2017 15:58
> Vastaanottaja: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi>
> Kopio: 'gdal-dev at lists.osgeo.org' (gdal-dev at lists.osgeo.org)
> <gdal-dev at lists.osgeo.org>; geoserver-devel at lists.sourceforge.net
Aihe:
> On Mon, Apr 3, 2017 at 2:32 PM, Rahkonen Jukka (MML)
> <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaito
> s.fi>> wrote:
With orthophoto coverages I believe that all cases could be
> handled with the default gridFunctions: startPoint at gml:Low, axisOrder +1
> +2, sequence rule “Linear”. As far as I have understood GDAL trusts that
> this is also what the other partners do. However, it seems that GeoServer
> developers have decided to handle the latitude-longitude axis flip in WCS
> 2.0.1 by changing the order of grid axis with a function instead of writing
> the offsetVectors to suit with the default +1 +2 axis order.
> <gml:coverageFunction>
> <gml:GridFunction>
> <gml:sequenceRule axisOrder="+2 +1">Linear</gml:sequenceRule>
> <gml:startPoint>0 0</gml:startPoint>
> </gml:GridFunction>
> </gml:coverageFunction>
> Hi Jukka,
> the decision was not arbitrary, and imho, necessary.
> Rasters pixels are normally represented as east/north, but OGC forces us to
> describe geographic data in lat/lon order.
So how do you tell the client,
> "look, I'm telling you that the axis order is north/east, but really, I'm
> giving you back data in east/north order instead"?
> Cheers
> Andrea
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Andrea Aime
> @geowolf
> Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054 Massarosa (LU)
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 339 8844549
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
> file/s allegato/i sono da considerarsi strettamente riservate. Il loro
> utilizzo è consentito esclusivamente al destinatario del messaggio, per le
> finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
> senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
> via e-mail e di procedere alla distruzione del messaggio stesso,
> cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20170404/0f5e83af/attachment-0001.html>
