[mapserver-dev] https url with MapServer as WMS client
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Thu Aug 24 04:36:23 PDT 2017
I do not believe that Mapserver has a switch for skipping the certificate check like GDAL has, see <UnsafeSSL>true</UnsafeSSL> in http://www.gdal.org/frmt_wms.html
This document describes how to add the self-signed certificate into your system http://mapserver.org/sq/ogc/wxs_secure.html.
-Jukka Rahkonen-
Lähettäjä: mapserver-dev [mailto:mapserver-dev-bounces at lists.osgeo.org] Puolesta Yves Jacolin
Lähetetty: 24. elokuuta 2017 14:20
Vastaanottaja: mapserver-dev List <mapserver-dev at lists.osgeo.org>
Aihe: [mapserver-dev] https url with MapServer as WMS client
Hello,
I have a layer set up as a wms client. The url is an https. MapServer log shows that curl doesn't manage this very well:
Status -60: server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none)
It seems that curl doesn't get the certificate to check the url and so failed. Do you have any idea how to manage this:
* is there a parameter somewhere to defined?
* do we need to install the remote certificate localy?
Thanks,
Y.
Training and support manager
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel (France) : +33 4 58 48 20 43
Tel (Swisstzerland) : +41 21 619 10 43
Mob. : +33 6 18 75 42 21
email : yves.jacolin at camptocamp.com<mailto:yves.jacolin at camptocamp.com>
http://www.camptocamp.com
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20170824/af1f355c/attachment.html>
