[mapserver-dev] Mapserver causes too many open files error
Jeff McKenna jmckenna at gatewaygeomatics.com
Mon Dec 11 15:31:37 PST 2017
+1 here.  Thanks Tamas.
-jeff
On 2017-12-11 5:49 PM, Lime, Steve D (MNIT) wrote:
> I’m ok with the changes… +1  Anyone else?
> *From:*Tamas Szekeres [mailto:szekerest at gmail.com]
> *Sent:* Sunday, December 10, 2017 12:06 PM
> *To:* Lime, Steve D (MNIT) <steve.lime at state.mn.us>
> *Cc:* mapserver-dev at lists.osgeo.org
> *Subject:* Re: [mapserver-dev] Mapserver causes too many open files error
> Hi Steve,
> Sorry for the confusion those commits were basically for testing the
> changes.
> I've now uploaded the commits I would prefer to see in mapserver/master:
> https://github.com/szekerest/mapserver/commit/def90bfed47abaaba7ec12f49eb218494a39cbdc
> https://github.com/szekerest/mapserver/commit/b74fd63f6838f1cf20cee7f1951e8cbac8da443e
> With regards to the FastCGI configuration I think that should also work
> without the USE_THREAD setting which is not affected with the changes.
> But if we don't set these environment variables, we would get back the
> original behavior.
> Best regards,
> Tamas
> 2017-12-05 21:40 GMT+01:00 Lime, Steve D (MNIT) <steve.lime at state.mn.us
> <mailto:steve.lime at state.mn.us>>:
>     Seem relatively minor. Couple of questions:
>     ·Since changes for item 1 would apply more generally, is there any
>     downside for FastCGI or should there be a 3^rd state where you have
>     threads AND are using Windows (or is that what you mean by being
>     switchable).
>     ·Why the symbol change from USE_THREAD to USE_THREAD_NOTSET?
>     Steve
>     <mailto:szekerest at gmail.com>]
>     *Sent:* Friday, December 01, 2017 9:51 AM
>     <mailto:mapserver-dev at lists.osgeo.org>
>     error
>     This change demonstrates what we need in #1
>     https://github.com/szekerest/mapserver/commit/87cacc6a37e802bc3af16656d45966c05deb4d62
>     For #2 this is the example:
>     https://github.com/szekerest/mapserver/commit/e16069972b43f837b47d0f736c2df4d5c0c7a475
>     Both of them should be switchable which is not yet added to this
>     code example.
>     Best regards,
>     Tamas
>     2017-12-01 15:48 GMT+01:00 Lime, Steve D (MNIT)
>     <steve.lime at state.mn.us <mailto:steve.lime at state.mn.us>>:
>         What does #1 entail? The other change is Windows specific so
>         seems ok – I don’t know what the right value should be of course.
>         *Sent:* Friday, December 01, 2017 1:53 AM
>         files error
>         We did some investigation in this regard and the following 2
>         changes could solve this specific problem on Windows and ASP.NET
>         <http://ASP.NET>.
>         1. Adding the ability to use a single cache instead of a
>         per-thread cache.
>         2. Increase the number of open stdio file handle limit for
>         Windows. Default is 512 the upper limit is 2048 accoding to this
>         documentation:
>         https://msdn.microsoft.com/en-us/library/6e3b887c.aspx
>         These settings should probably be controlled with compile
>         options or environment variables.
>         Any objections to apply such changes?
>         Best regards,
>         Tamas
>         2017-11-27 16:42 GMT+01:00 Lime, Steve D (MNIT)
>             The former is certainly simpler. How expensive is setting up
>             and clearing out the cache? Probably should look at Thomas’
>             RFC on the topic.
>             *From:*mapserver-dev
>             [mailto:mapserver-dev-bounces at lists.osgeo.org
>             <mailto:mapserver-dev-bounces at lists.osgeo.org>] *On Behalf
>             Of *Tamas Szekeres
>             *Sent:* Sunday, November 26, 2017 2:01 PM
>             *To:* mapserver-dev at lists.osgeo.org
>             *Subject:* [mapserver-dev] Mapserver causes too many open
>             files error
>             Hi Devs,
>             We experienced an issue with mapserver 7.x (comparing to
>             6.x) that it causes too many open file handles in a
>             multi-threaded environment. Actually the process is using
>             the ASP.NET <http://ASP.NET> backend where the web requests
>             are served through the ASP.NET <http://ASP.NET> worker
>             process by using a thread pool, and the process should be
>             considered as a long running process, where msCleanup is not
>             being called regularly.
>             By looking into the code the issue should probably be
>             dedicated to the global font cache approach implemented in
>             mapserver 7. Since freetype keeps the font files open, we
>             get the number of fonts used in the mapfile multiplied with
>             the thread pool size which may exceed the number of stdio
>             open file handle limit as per
>             https://msdn.microsoft.com/en-us/library/kdfaxaay(v=vs.140).aspx
>             With the former approach (ie. 6.x) the font cache was
>             implemented in the renderers and the cache cleanup was
>             happening on the renderer cleanup
>             in msFreeOutputFormat/msFreeMap.
>             Do you have any suggestions about a proper workaround to this?
>             I might think that we should either bind the font cache to
>             each map objects (like earlier) or use a single common font
>             cache for the entire process. I would probably prefer the
>             first one as soon as we want to clean up every resources
>             what a rendering session allocates.
>             Thanks,
>             Tamas
