[mapserver-dev] log2vis no multi-line support
Jeff McKenna
jmckenna at gatewaygeomatics.com
Fri Dec 22 11:06:08 PST 2017
Hi Jerry,
I am wondering, since log2vis seems to be deprecated (MapServer issue:
https://github.com/mapserver/mapserver/issues/5491), besides spitting
out an error, is there a way to better handle line breaks? In other
words, if we cannot use fribidi_log2vis() because it is deprecated, what
should we be using?
(Jerry's pull request: https://github.com/mapserver/mapserver/pull/5535)
(background for others: Jerry is a highschool developer contributing to
MapServer as part of the Google Code-in. If others can help provide
feedback here or in the pull request that would be very helpful)
-jeff
On 2017-12-20 12:02 PM, Jerry Huang wrote:
> It seems that log2vis is deprecated because it doesn't support
> multi-line paragraphs. See:
> https://lists.freedesktop.org/archives/fribidi/2008-January/000515.html
> I added a if statement that would throw an error given a multi-line
> paragraph.
