[mapserver-dev] RFC 118 - Vendor-specific WMS FILTER parameter
Daniel Morissette
dmorissette at mapgears.com
Thu Feb 9 08:08:07 PST 2017
Hi Jukka,
You raise very good questions from an OGC interoperability standpoint,
but to be honest I am not sure I have the answers to those questions.
The goal of the RFC is simply to take whatever is supported by the
current MapServer code in a WFS GetFeature FILTER and make it work in a
WMS GetMap FILTER. This has the benefit that client-side code that
builds OGC filters for WFS can apply the same filter to the
corresponding WMS layers (and I'm told there is code for doing that
already).
The examples in the RFC are taken from the msautotest suite, so the
simpler filters without namespace are definitely supported by MapServer.
I presume that it doesn't hurt to provide the full namespace stuff and I
actually see that this case is tested for WFS 2.0.0 in msautotest, but
to be fair I do not plan to do a full suite of OGC filter
interoperability testing. Just planning to use the current filter
implementation as is.
With respect to SRS and axis swapping, there is code in the WFS Filter
stuff that takes care of the swap of coordinates if necessary for WFS
1.1 and up, and I plan to have that handled the same way for WMS 1.3 and
up. The code seems to use the SRS of the request as the default if none
is provided in the filter.
You're right about the fact that if no WFS is available for a given
service then you'll have no way to discover the geometry and attribute
names without a WFS DescribeFeatureType. I'll add a mention of that in
the limitations.
The updated RFC is at
http://mapserver.org/development/rfc/ms-rfc-118.html
Thank you very much for the feedback. Does this address your concerns
with the understanding that the goal is simply to reuse the existing
filter stuff in the WMS context?
Daniel
P.S. CQL_FILTER would be very nice and maybe we should plan to add that
at some point, but that would require new developments beyond the scope
of this RFC. Thank you for pointing that out, I'll definitely keep it in
mind.
On 2017-02-09 3:48 AM, Rahkonen Jukka (MML) wrote:
> Hi,
> I doubt anybody is using the FILTER vendor option with Geoserver because it supports CQL_FILTER which is much less painless to use
> http://docs.geoserver.org/latest/en/user/filter/ecql_reference.html#filter-ecql-reference
> http://docs.geoserver.org/latest/en/user/tutorials/cql/cql_tutorial.html#cql-tutorial
> I guess that OGC XML filter is easier to implement for us. It seems by the RFC that these filters could be simplified when it comes to namespaces which makes them shorter and easier to write even the same filter would not work with schema validating servers:
> Mapserver filter:
> <Filter><DWithin><PropertyName>Geometry</PropertyName><gml:Point><gml:coordinates>-60.18,46.10</gml:coordinates></gml:Point><Distance units='dd'>0.05</Distance></DWithin></Filter>
> Geoserver filter:
> filter=%3CFilter%20xmlns:gml=%22http://www.opengis.net/gml%22%3E%3CIntersects%3E%3CPropertyName%3Ethe_geom%3C/PropertyName%3E%3Cgml:Point%20srsName=%224326%22%3E%3Cgml:coordinates%3E-74.817265,40.5296504%3C/gml:coordinates%3E%3C/gml:Point%3E%3C/Intersects%3E%3C/Filter%3E
> This reminds me about one practical problem with using OGC filters for spatial queries: User should know the name of the geometry field. If WFS is not active then Mapserver users do not have any way to know what name to use because we do not support DescribeLayer, or do we?
> However, Mapserver does internally know what geometry to use and also WFS BBOX query works as KVP without giving the name of the geometry column.
> Suggestion: do not require PropertyName in spatial filters, or accept anything
> <PropertyName>Foo</PropertyName>
> The example is GML2, would filter be limited to that or should it support also GML3? That would bring troubles, not least with srsName and axis order. How about srsName and default projection? If srsName is not given with the geometry in filter, is it interpreted to be the same as the SRS/CRS of GetMap?
> -Jukka Rahkonen-
> ________________________________________
> Hi Devs,
> FYI I just added RFC 118 about the addition of a vendor-specific FILTER
> parameter in the WMS interface to allow easier filtering of GetMap and
> GetFeatureInfo requests by client-side JS applications:
> I will leave the RFC open for discussions for the next few days and will
> be working on this during the code sprint this week.
> Daniel
> Daniel Morissette
> http://www.mapgears.com/
> T: +1 418-696-5056 #201
> http://evouala.com/ - Location Intelligence Made Easy
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
Daniel Morissette
