[mapserver-dev] [mapserver-users] Label position not as expected version 7.0.x
thomas bonfort
thomas.bonfort at gmail.com
Mon Jan 2 09:40:33 PST 2017
Ian,
It's the intented effect, with the label baseline aligned with the symbol
baseline. You can probably nudge it manually with an offset if you need to.
thomas
On Mon, Jan 2, 2017 at 6:30 PM Ian Walberg <ian.walberg at airborne.aero>
wrote:
> Folks,
> Happy New Year to everyone.
> Using version 7.0.x we are not seeing the label positon as we had for
> previous versions for mapserver.
> The vertical label position now appears to not center naturally on the
> text but is towards the bottom of the center line.
> Are we missing something?
> Thanks
> Ian
> MAP
> EXTENT 0.0 0.0 10.0 10.0
> SIZE 1024 720
> IMAGECOLOR 140 140 140
> SYMBOL
> NAME 'City'
> TYPE ELLIPSE
> POINTS 1 1 END
> FILLED true
> END
> LAYER
> NAME "Label position"
> TYPE POINT
> STATUS DEFAULT
> FEATURE
> POINTS
> 1.00 5.00
> 1.00 8.00
> END # POINTS
> END # FEATURE
> CLASS
> TEXT 'Label text'
> STYLE
> SYMBOL 'City'
> SIZE 12
> COLOR 255 255 255
> END # STYLE
> LABEL
> TYPE BITMAP
> SIZE 30
> COLOR 255 255 255
> POSITION CR
> END # LABEL
> END # CLASS
> END # LAYER
> END # MAP
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20170102/cb1cb393/attachment-0001.html>
