[mapserver-dev] Insert an 'INCLUDE' somewhere in a mapfile using the c/c++ ms API
Lime, Steve D (MNIT)
steve.lime at state.mn.us
Thu Jun 8 09:05:21 PDT 2017
If you've already parsed the mapfile then it's too late to use includes and you should modify the mapObj, etc... directly. Otherwise you'd need to modify the file itself (outside of MapServer), perhaps by reading the file as plain text and writing a temp file with your include that can be handed to MapServer. --Steve
-----Original Message-----
From: mapserver-dev [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Rémi Cresson
Sent: Thursday, June 08, 2017 4:02 AM
To: mapserver-dev at lists.osgeo.org
Subject: [mapserver-dev] Insert an 'INCLUDE' somewhere in a mapfile using the c/c++ ms API
Hello everybody,
I am producing mapfiles using the mapserver API from a C/C++ code of mine.
I am trying to insert an INCLUDE "my_mapfile.map" somewhere inside a
mapfile, using the c/c++ mapserver API. Ideally, I want to put this line
inside a given myLayer. I did not find a dedicated function to perform
this, and I was expecting if there is a (simple?) way to reach this goal?
Many thanks,
Rémi
mapserver-dev mailing list
https://lists.osgeo.org/mailman/listinfo/mapserver-dev
