[mapserver-dev] Mapfile keywords questions
Seth G
sethg at geographika.co.uk
Fri Jun 23 16:33:25 PDT 2017
Hi list,
I'm trying to get the definitive list of current Mapfile keywords and
syntax for a Mapfile parser I'm working on
(https://github.com/geographika/mappyfile).
I've gone through the MapServer docs, and also the sourcecode and have a
few keywords that aren't documented and I'm not sure are still used. If
anyone has any details on the list below it would be very useful. I can
open issues if necessary and update docs.
RELATIVETO - mentioned in
https://github.com/mapserver/mapserver/issues/1547 (from 2006) and is in
the maplexer.l file. It is not in the test mapfile created when the
issue was resolved
(https://trac.osgeo.org/mapserver/attachment/ticket/1547/test_points.map).
So it may never have been used?
COMPFILTER - http://www.mapserver.org/development/rfc/ms-rfc-113.html -
not used? Looks interesting! Should be added to
http://www.mapserver.org/mapfile/composite.html ?
GRATICULE - used to be a LAYER CONNECTION type, but now deprecated?
SCALETOKEN - should be in http://www.mapserver.org/mapfile/layer.html
Documented in http://www.mapserver.org/output/kerneldensity.html
LATLON - in maplexer.l but not sure where this would be used in a Mapfile.
JAVASCRIPT - it is a token in maplexer.l, but not sure where this would
be needed (javascript is in quotes as part of the GEOTRANSFORM options)
SCALE - again a token, but I can only find it as a LAYER processing
option - PROCESSING "SCALE=AUTO"
INDEX - not sure what this keyword is for (and hard to search for..)
SIMPLE, TITLE, VALUES - all in maplexer.l but not in docs.
COLORRANGE and DATARANGE - should be added to the STYLE doc page -
currently only documented at http://mapserver.org/output/kerneldensity.html
Some keywords only seem valid as part of Mapscript rather than a
Mapfile: BANDSITEM, OVERLAYSYMBOL, EQUALS, MULTIPLE, SINGLE (I think the
last 2 are PHP join types only?)
Also some non-quoted values also seem to be missing from the docs:
LINECAP - http://www.mapserver.org/mapfile/style.html?highlight=linecap
- should TRIANGLE be a documented option? It is in maplexer.l and also
mentioned at
http://www.mapserver.org/mapfile/symbology/construction.html#sym-construction
Regards,
Seth
web: http://geographika.co.uk
twitter: @geographika
