[mapserver-dev] Downloading GeoTIFFs with overviews from WCS
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Tue May 2 13:15:16 PDT 2017
Hi Michael,
I don't believe that overviews could be created by fiddling with outputformat. The usual GDAL workflow is to create overviews as post-processing step with gdaladdo.
-Jukka-
-----Alkuperäinen viesti-----
Michael Smith wrote:
Re: [mapserver-dev] Downloading GeoTIFFs with overviews from WCS
Jukka,
Can you specify the overview creation in the format options to the geotiff driver?
Mike
Michael Smith
Remote Sensing/GIS Center
US Army Corps of Engineers
On 5/2/17, 3:12 PM, "mapserver-dev on behalf of Rahkonen Jukka (MML)"
<mapserver-dev-bounces at lists.osgeo.org on behalf of jukka.rahkonen at maanmittauslaitos.fi> wrote:
>Hi,
>For downloading raster images from WCS so that they could used directly
>in applications in most effective way they should be tiled, compressed,
>and include overviews. Compression and tiling can be handled fine with
>Mapserver and GeoTIFF Coverage Encoding Profile extension. Only thing
>that is missing is the creation of overviews on the server side.
>If Mapserver would be able to deliver GeoTIFFs enhanced with overviews
>some days, would it be then from WPS through some CreateOverviews
>process, or from WCS by applying out own vendor options?
>-Jukka Rahkonen-
>_______________________________________________
>mapserver-dev mailing list
>mapserver-dev at lists.osgeo.org
>https://lists.osgeo.org/mailman/listinfo/mapserver-dev
