[mapserver-dev] drop shadow for labels
Stephen Woodbridge woodbri at swoodbridge.com
Sun May 21 16:06:37 PDT 2017
FORCE TRUE is likely going to generate other problems.
Did you try this without FORCE TRUE. This:
http://mapserver.org/development/rfc/ms-rfc-77.html
leads me to believe that multiple label blocks in a class use the same
label point and therefore should not need the FORCE TRUE. And I think
you can have multiple labels optionally with leader lines on a single
point like this.
-Steve W
On 5/21/2017 5:13 PM, Tamas Szekeres wrote:
> We could indeed achieve similar effect by duplicating the label
> definition, however we need to set FORCE TRUE for the upper label to get
> it displayed at all.
> Best regards,
> Tamas
> 2017-05-21 22:30 GMT+02:00 Stephen Woodbridge <woodbri at swoodbridge.com
> <mailto:woodbri at swoodbridge.com>>:
>     Ahhh, sorry. I believe that you can include the label block twice,
>     the first time you draw the shadow, with some offset and using your
>     shadow color, the second time you draw it with the foreground color.
>     You should open an issue against the docs they are not correct.
>     There might be an FRC that covers this change, but I'm not seeing one.
>     On 5/21/2017 4:13 PM, Tamas Szekeres wrote:
>         I've already learnt, that BACKGROUNDCOLOR,
>         BACKGROUNDSHADOWCOLOR, BACKGROUNDSHADOWSIZE can be replaced with
>         label styles, but what about SHADOWCOLOR and SHADOWSIZE?
>         Thanks,
>         Tamas
>         2017-05-21 22:01 GMT+02:00 Stephen Woodbridge
>         <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>
>         <mailto:woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>>>:
>              On 5/21/2017 1:54 PM, Tamas Szekeres wrote:
>                  Hi,
>                  Could someone explain how to configure drop shadow for
>         label in
>                  mapserver 7.x ?
>                  It looks like the SHADOWCOLOR/SHADOWSIZE implementation
>         has been
>                  stripped from the code and I'm not sure what replaces
>         that option.
>                  The documentation is very brief in this regard.
>              BACKGROUNDCOLOR [r] [g] [b] | [hexadecimal string]
>                   Color to draw a background rectangle (i.e. billboard).
>         Off by
>              default.
>                   Note
>                   Removed in 6.0. Use a LABEL STYLE object with
>         GEOMTRANSFORM
>              labelpoly and COLOR.
>              BACKGROUNDSHADOWCOLOR [r] [g] [b] | [hexadecimal string]
>         shadow.
>              Off by default.
>                   Note
>         GEOMTRANSFORM
>              labelpoly, COLOR and OFFSET.
>              BACKGROUNDSHADOWSIZE [x][y]
>                   How far should the background rectangle be offset?
>         Default is 1.
>                   Note
>         GEOMTRANSFORM
>         http://mapserver.org/mapfile/label.html#label-style
>         <http://mapserver.org/mapfile/label.html#label-style>
>         <http://mapserver.org/mapfile/label.html#label-style>>
>              STYLE
>                 GEOMTRANSFORM 'labelpoly'
>                 COLOR 153 153 153
>                 OFFSET 3 2
>              END # STYLE
>              STYLE
>                 COLOR 255 0 0
>              END # STYLE
>              This email has been checked for viruses by Avast antivirus
>         software.
>         https://www.avast.com/antivirus
>         <https://www.avast.com/antivirus>
>         <https://www.avast.com/antivirus <https://www.avast.com/antivirus>>
>              _______________________________________________
>              mapserver-dev mailing list
>         mapserver-dev at lists.osgeo.org
>         <mailto:mapserver-dev at lists.osgeo.org>
>         <mailto:mapserver-dev at lists.osgeo.org>>
>         https://lists.osgeo.org/mailman/listinfo/mapserver-dev
>         <https://lists.osgeo.org/mailman/listinfo/mapserver-dev>
>         <https://lists.osgeo.org/mailman/listinfo/mapserver-dev>>
This email has been checked for viruses by Avast antivirus software.
