[mapserver-dev] drop shadow for labels
Tamas Szekeres szekerest at gmail.com
Mon May 29 05:13:37 PDT 2017
I agree this is a regression issue that should be fixed.
But should we also need to deprecate SHADOWCOLOR and SHADOWSIZE or removing
that support in the code was also a regression? I don't see in the
documentation that SHADOWCOLOR and SHADOWSIZE are no more supported and the
migration guide doesn't mention a compatible solution either.
We should also make OFFSET as a bindable attribute, since SHADOWSIZE was
also bindable.
Best regards,
Tamas
2017-05-22 20:29 GMT+02:00 Lime, Steve D (MNIT) <steve.lime at state.mn.us>:
> Sure looks to be a regression.
>   Works w/two label blocks: http://maps1.dnr.state.mn.us/
> cgi-bin/mapserv64?map=/usr/local/mapserver/apps/test/
> drop_shadow/test.map&mode=map
>   Doesn't work: w/two label blocks: http://maps1.dnr.state.mn.us/
> cgi-bin/mapserv70?map=/usr/local/mapserver/apps/test/
> Mapfile follows... FORCE TRUE gets the label to appear correctly but that
> shouldn't be necessary. --Steve
> MAP
>   NAME 'drop shadows'
>   SIZE 500 500
>   EXTENT 0 0 499 499
>   FONTSET /usr/local/mapserver/fonts/fonts.list
>   IMAGECOLOR 232 232 232
>   LAYER
>     NAME 'label'
>     TYPE POINT
>     STATUS DEFAULT
>     FEATURE
>       POINTS 250 250 END
>       TEXT 'Sample Text'
>     END
>     TRANSFORM FALSE
>     CLASS
>       LABEL
>         TYPE TRUETYPE
>         FONT arial
>         SIZE 16
>         COLOR 181 181 181
>         OFFSET 3 3
>       END
>       LABEL
>         TYPE TRUETYPE
>         FONT arial
>         SIZE 16
>         COLOR 0 0 0
>         OUTLINECOLOR 255 255 255
>       END
>     END
>   END
> END
> -----Original Message-----
> From: mapserver-dev [mailto:mapserver-dev-bounces at lists.osgeo.org] On
> Behalf Of Stephen Woodbridge
> Sent: Sunday, May 21, 2017 6:07 PM
> To: Tamas Szekeres <szekerest at gmail.com>
> Cc: mapserver-dev at lists.osgeo.org
> Subject: Re: [mapserver-dev] drop shadow for labels
> FORCE TRUE is likely going to generate other problems.
> Did you try this without FORCE TRUE. This:
> http://mapserver.org/development/rfc/ms-rfc-77.html
> leads me to believe that multiple label blocks in a class use the same
> label point and therefore should not need the FORCE TRUE. And I think
> you can have multiple labels optionally with leader lines on a single
> point like this.
> -Steve W
> On 5/21/2017 5:13 PM, Tamas Szekeres wrote:
> > We could indeed achieve similar effect by duplicating the label
> > definition, however we need to set FORCE TRUE for the upper label to get
> > it displayed at all.
> > Best regards,
> > Tamas
> > 2017-05-21 22:30 GMT+02:00 Stephen Woodbridge <woodbri at swoodbridge.com
> > <mailto:woodbri at swoodbridge.com>>:
> >     Ahhh, sorry. I believe that you can include the label block twice,
> >     the first time you draw the shadow, with some offset and using your
> >     shadow color, the second time you draw it with the foreground color.
> >     You should open an issue against the docs they are not correct.
> >     There might be an FRC that covers this change, but I'm not seeing
> one.
> >     On 5/21/2017 4:13 PM, Tamas Szekeres wrote:
> >         I've already learnt, that BACKGROUNDCOLOR,
> >         BACKGROUNDSHADOWCOLOR, BACKGROUNDSHADOWSIZE can be replaced with
> >         label styles, but what about SHADOWCOLOR and SHADOWSIZE?
> >         Thanks,
> >         Tamas
> >         2017-05-21 22:01 GMT+02:00 Stephen Woodbridge
> >         <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>
> >         <mailto:woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com
> >              On 5/21/2017 1:54 PM, Tamas Szekeres wrote:
> >                  Hi,
> >                  Could someone explain how to configure drop shadow for
> >         label in
> >                  mapserver 7.x ?
> >                  It looks like the SHADOWCOLOR/SHADOWSIZE implementation
> >         has been
> >                  stripped from the code and I'm not sure what replaces
> >         that option.
> >                  The documentation is very brief in this regard.
> >              BACKGROUNDCOLOR [r] [g] [b] | [hexadecimal string]
> >                   Color to draw a background rectangle (i.e. billboard).
> >         Off by
> >              default.
> >                   Note
> >                   Removed in 6.0. Use a LABEL STYLE object with
> >         GEOMTRANSFORM
> >              labelpoly and COLOR.
> >              BACKGROUNDSHADOWCOLOR [r] [g] [b] | [hexadecimal string]
> >         shadow.
> >              Off by default.
> >                   Note
> >         GEOMTRANSFORM
> >              labelpoly, COLOR and OFFSET.
> >              BACKGROUNDSHADOWSIZE [x][y]
> >                   How far should the background rectangle be offset?
> >         Default is 1.
> >                   Note
> >         GEOMTRANSFORM
> >         http://mapserver.org/mapfile/label.html#label-style
> >         <http://mapserver.org/mapfile/label.html#label-style>
> >         <http://mapserver.org/mapfile/label.html#label-style>>
> >              STYLE
> >                 GEOMTRANSFORM 'labelpoly'
> >                 COLOR 153 153 153
> >                 OFFSET 3 2
> >              END # STYLE
> >              STYLE
> >                 COLOR 255 0 0
> >              END # STYLE
> >              This email has been checked for viruses by Avast antivirus
> >         software.
> >         https://www.avast.com/antivirus
> >         <https://www.avast.com/antivirus>
> >         <https://www.avast.com/antivirus <https://www.avast.com/
> antivirus>>
> >              _______________________________________________
> >              mapserver-dev mailing list
> >         <mailto:mapserver-dev at lists.osgeo.org>
> >         <mailto:mapserver-dev at lists.osgeo.org>>
> >         https://lists.osgeo.org/mailman/listinfo/mapserver-dev
> >         <https://lists.osgeo.org/mailman/listinfo/mapserver-dev>
> >         <https://lists.osgeo.org/mailman/listinfo/mapserver-dev>>
> This email has been checked for viruses by Avast antivirus software.
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20170529/224defe1/attachment.html>
