[mapserver-dev] Using updateFromString on existing items
Tamas Szekeres szekerest at gmail.com
Sun Oct 8 10:49:55 PDT 2017
Hi Devs,
Is that a supported use case to apply updateFromString on an existing item
or it should only be used only on a newly created item?
For example when I use layerObj.updateFromString on an existing layer I get
the following error
loadProjection(): General error message. Projection is already initialized.
Multiple projection definitions are not allowed in this object. (line 10)
This is because we don't have a proper cleanup code on the existing layer
before calling loadLayer on it. The same applies to the other object types.
Thanks,
Tamas
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20171008/fadc2fde/attachment.html>
