[mapserver-dev] Using updateFromString on existing items
Tamas Szekeres szekerest at gmail.com
Mon Oct 9 08:17:34 PDT 2017
Hi Steve,
It is hard to interpret what are the allowed "minor edits" in such case.
Neither the documentation or the corresponting rfc provides any guidance.
One can think a reasonable use case to completely deserialize the object
state by using these methods.
Do we have a simple approach to reset the state of the object (as it was
newly created) before calling the updateFromString method?
Thanks,
Tamas
2017-10-09 16:23 GMT+02:00 Lime, Steve D (MNIT) <steve.lime at state.mn.us>:
> The original use case was to facilitate minor edits to existing object
> properties but not sub-objects. For example, you can't replace all the
> classes in a layer through a string update to the layer itself. We
> certainly could make all that work cleaner if there were demand.
> At least you get a proper error message... ;-)
> Steve
> *From:* mapserver-dev <mapserver-dev-bounces at lists.osgeo.org> on behalf
> of Tamas Szekeres <szekerest at gmail.com>
> *Sent:* Sunday, October 8, 2017 12:49:55 PM
> *To:* mapserver-dev at lists.osgeo.org
> *Subject:* [mapserver-dev] Using updateFromString on existing items
> Hi Devs,
> Is that a supported use case to apply updateFromString on an existing item
> or it should only be used only on a newly created item?
> For example when I use layerObj.updateFromString on an existing layer I
> get the following error
> loadProjection(): General error message. Projection is already
> initialized. Multiple projection definitions are not allowed in this
> object. (line 10)
> This is because we don't have a proper cleanup code on the existing layer
> before calling loadLayer on it. The same applies to the other object types.
> Thanks,
> Tamas
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20171009/6ec3ca69/attachment.html>
