[mapserver-dev] Using updateFromString on existing items
    Lime, Steve D (MNIT)
    steve.lime at state.mn.us
    Tue Oct 10 11:36:27 PDT 2017
I was thinking more about this and I think there are several possibilities if you want to completely repopulate a layer (or other object) from a string. Personally, I’d leave the updateFromString() method alone and add a reset/init or whatever method that basically free’s the object and then re-initializes it resulting in an object that is ready to load a definition into. For a layer that would clear out projections, classes, etc…, for a class that would clear out styles, and so on… Code would look something like:
  $layer = $map->getLayerByName(‘foo’);
  $layer->reset();
  $layer->updateFromString($fullLayerDefinitionString);
One could also add new method to explicitly do the reset and update (e.g. resetFromString) or perhaps add a flag to the updateFromString method to reset.
Steve
From: mapserver-dev [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Lime, Steve D (MNIT)
Sent: Monday, October 09, 2017 11:12 AM
To: Tamas Szekeres <szekerest at gmail.com>
Cc: mapserver-dev at lists.osgeo.org
Subject: Re: [mapserver-dev] Using updateFromString on existing items
I think we need to spend a little time looking at the code and the original RFC to properly document the “as is” behavior and then determine if any changes are necessary. Looking at the layer code I think my reference to “minor edits” is wrong. If you update a layer from a string in MapScript and that string contains classes then *new* classes are added to the layer object. If you want to update an existing class you’d have to update it directly from a string, not via the parent layer. Resetting the object would be a pretty drastic change. It may be that only projections need some sort of intervention to clear things out…
Steve
From: Tamas Szekeres [mailto:szekerest at gmail.com]
Sent: Monday, October 09, 2017 10:18 AM
To: Lime, Steve D (MNIT) <steve.lime at state.mn.us<mailto:steve.lime at state.mn.us>>
Cc: mapserver-dev at lists.osgeo.org<mailto:mapserver-dev at lists.osgeo.org>
Hi Steve,
It is hard to interpret what are the allowed "minor edits" in such case. Neither the documentation or the corresponting rfc provides any guidance.
One can think a reasonable use case to completely deserialize the object state by using these methods.
Do we have a simple approach to reset the state of the object (as it was newly created) before calling the updateFromString method?
Thanks,
Tamas
2017-10-09 16:23 GMT+02:00 Lime, Steve D (MNIT) <steve.lime at state.mn.us<mailto:steve.lime at state.mn.us>>:
The original use case was to facilitate minor edits to existing object properties but not sub-objects. For example, you can't replace all the classes in a layer through a string update to the layer itself. We certainly could make all that work cleaner if there were demand.
At least you get a proper error message... ;-)
Steve
From: mapserver-dev <mapserver-dev-bounces at lists.osgeo.org<mailto:mapserver-dev-bounces at lists.osgeo.org>> on behalf of Tamas Szekeres <szekerest at gmail.com<mailto:szekerest at gmail.com>>
Sent: Sunday, October 8, 2017 12:49:55 PM
To: mapserver-dev at lists.osgeo.org<mailto:mapserver-dev at lists.osgeo.org>
Subject: [mapserver-dev] Using updateFromString on existing items
Hi Devs,
Is that a supported use case to apply updateFromString on an existing item or it should only be used only on a newly created item?
For example when I use layerObj.updateFromString on an existing layer I get the following error
loadProjection(): General error message. Projection is already initialized. Multiple projection definitions are not allowed in this object. (line 10)
This is because we don't have a proper cleanup code on the existing layer before calling loadLayer on it. The same applies to the other object types.
Thanks,
Tamas
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20171010/9c45bed4/attachment.html>
