[mapserver-dev] Is there a way to see Travis CI test output files?
Dan Little
theduckylittle at gmail.com
Wed Oct 11 05:01:11 PDT 2017
You should be able to click on the link for the travis results on the
GitHub PR, then in the derivatives table at the bottom click on the build
number and you'll get the run log.
On Tue, Oct 10, 2017 at 2:41 PM, Lime, Steve D (MNIT) <
steve.lime at state.mn.us> wrote:
> I’m sure there is and I’m just not looking in the right spot. I’d like to
> access the generated image output for a failed test associated with a
> build. --Steve
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20171011/efae24d3/attachment.html>
