[mapserver-dev] msPostGISLayerGetExtent should consider layer filter
Tamas Szekeres
szekerest at gmail.com
Sun Apr 15 11:25:30 PDT 2018
Added a PR to implement this one
https://github.com/mapserver/mapserver/pull/5585
Best regards,
Tamas
2018-04-08 21:29 GMT+02:00 Tamas Szekeres <szekerest at gmail.com>:
> I think it would be faster to execute the ST_Extent aggregate on a smaller
> set of geometries (though it might depend on the implementation).
> The benefit would probably be that LayerGetExtent could be used to
> calculate the actual extent of the layer.
> Best regards,
> Tamas
> 2018-04-06 9:24 GMT+02:00 Rahkonen Jukka (MML) <jukka.rahkonen@
> maanmittauslaitos.fi>:
>> Hi,
>> What would be the benefits of appending the ”where”? How often the query
>> is run and can it be slow?
>> -Jukka Rahkonen-
>> *Lähettäjä:* mapserver-dev [mailto:mapserver-dev-bounces at lists.osgeo.org]
>> *Puolesta *Tamas Szekeres
>> *Lähetetty:* 6. huhtikuuta 2018 10:19
>> *Vastaanottaja:* mapserver-dev at lists.osgeo.org
>> *Aihe:* [mapserver-dev] msPostGISLayerGetExtent should consider layer
>> filter
>> Hi Devs,
>> We would require that msPostGISLayerGetExtent would apply the specified
>> filter when calculating the layer extent. This would probably be happen by
>> appending the "where" clause from msPostGISBuildSQLWhere to
>> sqlExtentTemplate. Does this make sense?
>> I've checked the code and some of the drivers consider the filter and
>> some are not, so I'm not completely sure about the expected behaviour.
>> Best regards,
>> Tamas
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20180415/00cef046/attachment.html>
