[mapserver-dev] Travis Builds broken?
Seth G
sethg at geographika.co.uk
Sun Jun 17 22:15:30 PDT 2018
Hi all,
The Travis MapServer builds seem to be failing at the moment with the following error:
E: Unable to locate package postgresql-9.1-postgis-2.1
E: Couldn't find any package by glob 'postgresql-9.1-postgis-2.1'
E: Couldn't find any package by regex 'postgresql-9.1-postgis-2.1'
E: Unable to locate package postgresql-9.1-postgis-2.1-scripts
E: Couldn't find any package by glob 'postgresql-9.1-postgis-2.1-scripts'
E: Couldn't find any package by regex 'postgresql-9.1-postgis-2.1-scripts'
The command "sudo apt-get install protobuf-c-compiler libprotobuf-c0-dev bison flex python-lxml libfribidi-dev swig cmake librsvg2-dev colordiff postgis postgresql-9.1 postgresql-9.1-postgis-2.1 postgresql-9.1-postgis-2.1-scripts libpq-dev libpng12-dev libjpeg-dev libgif-dev libgeos-dev libgd2-xpm-dev libfreetype6-dev libfcgi-dev libcurl4-gnutls-dev libcairo2-dev libgdal1-dev libproj-dev libxml2-dev python-dev php5-dev libexempi-dev lcov lftp" failed and exited with 100 during .
For example - https://travis-ci.org/mapserver/mapserver/builds/393190616
Have the postgis packages been removed from the repository?
Regards,
Seth
web:http://geographika.co.uk
twitter: @geographika
