[mapserver-dev] PHP-Mapscript via SWIG/PHP Mapscript "Native" for PHP7
Seth G sethg at geographika.co.uk
Fri Oct 19 06:14:12 PDT 2018
Hi Alex,
I'm not sure if you are aware of them (I have only recently looked at
the Python MapScript tests in the same place), but there is a suite of
PHP MapScript tests in
https://github.com/mapserver/mapserver/tree/master/msautotest/phpThese are run by Travis via the MakeFile -
https://github.com/mapserver/mapserver/blob/913d68e3804a4bea2b5f049ab1b5413f8a9b5dc5/Makefile#L43It looks like these are all passing for your pull request. Could these
tests also be run on the SWIG PHP bindings?Regards,
Seth
web:http://geographika.co.uk
twitter: @geographika
On Fri, Oct 19, 2018, at 12:47 AM, Alexander Gabriel wrote:
> I removed some uneeded code related to thread-safety that is not
> needed because there are no module global variables from PHP/Mapscript
> to be able to compile PHP/Mapscript in thread-safe environments (even
> a Linux-, not just Windows-problem) and opened a new PR:
> https://github.com/mapserver/mapserver/pull/5682> If you have any feedback or recommendations, please let me know.
> Kind regards,
> Alex
> *Von:* Lime, Steve D (MNIT) [mailto:steve.lime at state.mn.us]
> *Gesendet:* Freitag, 12. Oktober 2018 01:42 *An:* Alexander Gabriel;
> Seth G; mapserver-dev at lists.osgeo.org *Betreff:* Re: [mapserver-dev]
> PHP-Mapscript via SWIG>
> I don’t want to sit on PHP7 and the other MapScript improvements and
> would vote for something sooner rather than later. Those are enough
> for 7.4 IMHO.
>  Planning for an 8.0 release should be more comprehensive. A good
>  sprint activity...
>  —Steve>
> *From:* Alexander Gabriel <Alexander.Gabriel at digital-infinity.de>
> *Sent:* Thursday, October 11, 2018 6:01:21 PM *To:* Lime, Steve D
> (MNIT); Seth G; mapserver-dev at lists.osgeo.org *Subject:* AW: [mapserver-
> dev] PHP-Mapscript via SWIG>
> Hi again,
> not sure what i did wrong in summer - or now ;) - but i was able to
> build with PHP 7.2.11 x64 NTS on Windows.> Maybe we can get this running.
> Will continue tomorrow or on the weekend :)
> How is the roadmap for 7.4?
> Is there already a release-date?
> Alex
> *Gesendet:* Freitag, 12. Oktober 2018 00:02 *An:* Alexander Gabriel;
> Seth G; mapserver-dev at lists.osgeo.org *Betreff:* RE: [mapserver-dev]
> I think Windows is key since Swig can’t help either.
> *From:* Alexander Gabriel [mailto:Alexander.Gabriel at digital-
> infinity.de] *Sent:* Thursday, October 11, 2018 4:39 PM *To:* Lime,
> Steve D (MNIT) <steve.lime at state.mn.us>; Seth G
> <sethg at geographika.co.uk>; mapserver-dev at lists.osgeo.org *Subject:*
> AW: [mapserver-dev] PHP-Mapscript via SWIG>
> Havgin both for some kind of transition-period is not a bad idea.
> I tried several hours to get the patch from bjoern running on
> windows (it works fine on linux) but failed and got stuck so i
> focused on swig.>
> Alex
> *Von:* mapserver-dev [mailto:mapserver-dev-bounces at lists.osgeo.org]
> *Im Auftrag von *Lime, Steve D (MNIT) *Gesendet:* Donnerstag, 11.
> Oktober 2018 23:11 *An:* Seth G; mapserver-dev at lists.osgeo.org
> *Betreff:* Re: [mapserver-dev] PHP-Mapscript via SWIG>
> Definitely cause for a 7.4 release. Maybe sooner rather than later.
> There’s also a PHP/MapScript for PHP7 out there – native PHP, no Swig
> out there (https://github.com/bjoernboldt/mapscript-php7,
> https://github.com/mapserver/mapserver/pull/5461). I’m curious if
> folks think both should be part of a 7.4 release. Do we want both
> interfaces or do we focus on SWIG only moving foward?>
> --Steve
> *From:* mapserver-dev [mailto:mapserver-dev-bounces at lists.osgeo.org]
> *On Behalf Of *Seth G *Sent:* Thursday, October 11, 2018 3:41 PM *To:*
> mapserver-dev at lists.osgeo.org *Subject:* Re: [mapserver-dev] PHP-
> Mapscript via SWIG>
> Hi Alex,
> There don't seem to be any objections or concerns, and as Steve
> pointed out as this is brand new it won't break anything.> I've merged to master, and will be following up with several other
> mapscript related changes (mainly Python).> Perhaps this can form the basis of a 7.4 release?
> Seth
> On Tue, Oct 9, 2018, at 5:33 PM, Alexander Gabriel wrote:
>> Hi together,
>> i prepared my patches to be merged into master branch:
>> https://github.com/mapserver/mapserver/pull/5675>>
>> There are a few issues in the moment which prevent testing my patches
>> with AppVeyor (https://gitlab.kitware.com/cmake/cmake/issues/18421)
>> and building it Thread-Safe on Windows
>> (https://github.com/swig/swig/commit/224bb9e0232a219b7cefd23472b592b39e277f46)
>> so only users that use current development state of SWIG and current
>> development state of CMake will be able to compile this on Windows
>> for Thread-Safe PHP (CMakeLists.txt checks for correct versions).>>
>> Because i think, there are more people waiting for PHP/Mapscript on
>> Linux than on Windows, it would be good to merge this, don't
>> advertise Mapscript for Windows as supported, wait until SWIG 4.0 and
>> CMake 3.13 get released and then look for supporting Windows again.>>
>> I'm interessted in feedback. If you have any suggestions, ideas or
>> any other feedback, please let me know. Seth (@geographika) offered
>> to merge in a few days if there are no suggested changes.>>
>> Thank you.
>> Kind regards,
>> Alex
>> *Im Auftrag von *Lime, Steve D (MNIT) *Gesendet:* Montag, 25. Juni
>> 2018 16:35 *An:* mapserver-dev at lists.osgeo.org *Betreff:* [mapserver-
>> dev] 7.2 release... and a question...>>
>> While PHP support for 7.2 was omitted  because of confusion on RFC
>> status, I’ve been watching Alexander (@AlexanderGabriel) has been
>> working hard the last 10 days to resurrect the SWIG/PHP work. See
>> ticket https://github.com/mapserver/mapserver/issues/5252 and the
>> pull request https://github.com/mapserver/mapserver/pull/5623.>>
>> Given the SWIG/PHP support is brand new and wouldn’t have any
>> backwards compatibility issues. So, do we include it and have one
>> more beta?>>
>> --Steve
>> _________________________________________________
>> mapserver-dev mailing list
>> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20181019/14955e3c/attachment-0001.html>
