[mapserver-dev] merge strategy between master and stable branch
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Oct 22 09:36:54 PDT 2018
There is nothing happening magically, sorry to inform. For the 7.2
release I had to do this manually with lovely git commands, very tricky.
-jeff
On 2018-10-22 1:33 PM, Lime, Steve D (MNIT) wrote:
> There are scripts that merge upstream (I believe Thomas and Even setup originally) on a regular basis (daily I believe). I'll look for the docs... So basically you make your changes to the appropriate branch and then they propagate automatically.
> -----Original Message-----
> From: mapserver-dev [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Tom Kralidis
> Sent: Monday, October 22, 2018 11:12 AM
> To: mapserver-dev at lists.osgeo.org
> Subject: [mapserver-dev] merge strategy between master and stable branch
> Hi all: I recently pushed some fixes to branch-7-2 and asked whether/how merging to master is being done. See Jeff M's comments at [1] and irc convo at [2].
> Is the expectation that the release manager will merge branch fixes into master at some point? Is there a process to do so? As a committer I am just following through to ensure my fixes are both in stable branch and master.
> Sorry if this is already discussed / documented (if yes, is there a link somewhere)?
> Thanks
> ..Tom
> [1] https://github.com/mapserver/mapserver/pull/5684#issuecomment-431430953
> [2] http://irclogs.geoapt.com/mapserver/%23mapserver.2018-10-22.log
