[mapserver-dev] Memory leak in mapcache
Stephen Woodbridge
stephenwoodbridge37 at gmail.com
Mon Apr 15 07:54:23 PDT 2019
Is it possible that this is related to using the cache type="memcache"
I have not seen this behavior using cache type="disk"
I'm not saying the the memory usage is memcache, but might be a leak in
the apache code talking to memcache, versus that talking to disk cache.
Do you have a setup where you could switch your cache from memcache to
disk for a test.
-Steve W
On 4/15/2019 4:36 AM, Patrick Valsecchi wrote:
> Hi Thomas, Long time no see!
> Every kind of request leaks. Even a WMS GetCapabilities (done by the
> health-check) leaks, but at a lesser rate than a GetMap. The web UI
> does requests in //, but the ingress limits at 10 connection in //.
> And it's not just that it allocates a big chunk of memory and stays
> there. It leaks continuously until the OOM wakes up and kills one of
> apache's worker. I had to set a limit of 100 requests (every 100
> requests the worker process is killed and a new one is forked) per
> worker to keep memory usage at bay.
> Thanks
> On Fri, Apr 12, 2019 at 7:12 PM thomas bonfort
> <thomas.bonfort at gmail.com <mailto:thomas.bonfort at gmail.com>> wrote:
> Hi Patrick,
> What kind of requests is mapcache responding to, and at what
> concurrency? Serving multiple large wms requests is typically an
> example where large chunks of memory will be allocated.
> thomas
> On Fri, Apr 12, 2019 at 12:42 AM Patrick Valsecchi
> <patrick.valsecchi at camptocamp.com
> <mailto:patrick.valsecchi at camptocamp.com>> wrote:
> Hi,
> I'm using mapcache v1.6.1 (tested as well with a master build)
> in docker and I can see huge memory increases in the apache
> process memory usage when mapcache is used (it's the only
> thing this apache instance is serving). The thing is
> configured like that:
> <mapcache>
> <cache name="default" type="memcache">
> <server>
> <host>prod-2-4-c2cgeoportal-memcached</host>
> <port>11211</port>
> </server>
> </cache>
> <tileset name="map">
> <source>map</source>
> <cache>default</cache>
> <grid>swissgrid_005</grid>
> <metatile>5 5</metatile>
> <metabuffer>128</metabuffer>
> <format>image/png</format>
> <expires>3600</expires> <!-- 1 hour -->
> <auto_expire>13800</auto_expire> <!-- 4 hours -->
> </tileset>
> I can see that memcached is used in it's stats and only
> mapcache uses it.
> But the the memory usage of the whole mapcache container looks
> like that:
> Each dip in usage is when the OOM kills one of the apache
> workers (out of a maximum of 3 workers). I have configured a
> memory limit in docker at 512MB.
> Nothing shows up in the apache logs.
> Are there any known memory leaks? Do I have a bad
> configuration? I could have the apache workers restarted every
> 10 queries, but that would be utterly ugly and inefficient...
> Thanks for your help.
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> <mailto:mapserver-dev at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
