[mapserver-dev] Working on adopting PROJ 6 API
    Lime, Steve D (MNIT)
    steve.lime at state.mn.us
    Fri Aug 23 06:01:24 PDT 2019
Thanks Even! Any guess on how big an effort (hrs) this might be? We do have a small project budget and I wonder if work so central would be worth supporting with more than good will and thanks.
There are other activities in the same boat so it's probably a topic for the next PSC meeting.
--Steve
From: mapserver-dev <mapserver-dev-bounces at lists.osgeo.org> on behalf of Even Rouault <even.rouault at spatialys.com>
Sent: Thursday, August 22, 2019 11:16 AM
To: mapserver-dev at lists.osgeo.org <mapserver-dev at lists.osgeo.org>
Subject: [mapserver-dev] Working on adopting PROJ 6 API
FYI and to avoid duplication of effort, I've just started working on making
MapServer use PROJ 6' proj.h API instead of the venerable proj_api.h.
For now, I'll try my best to keep the old code paths using proj_api.h, but
can't tell how viable this is.
Even
https://gcc01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.spatialys.com&data=02%7C01%7Csteve.lime%40state.mn.us%7C31003b884b644850cc5e08d7271c1bb5%7Ceb14b04624c445198f26b89c2159828c%7C0%7C0%7C637020873983839060&sdata=W4nboLzRnKNyPqKjQOtiUP0Cg4xvBczN4ZDwvJK3ZQc%3D&reserved=0
mapserver-dev mailing list
https://gcc01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fmapserver-dev&data=02%7C01%7Csteve.lime%40state.mn.us%7C31003b884b644850cc5e08d7271c1bb5%7Ceb14b04624c445198f26b89c2159828c%7C0%7C0%7C637020873983839060&sdata=lBgMmys71YFMl274oYWP8Dzc0POWVUNz4ueALmQTjts%3D&reserved=0
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20190823/78e98302/attachment.html>
