[mapserver-dev] Backport bot no longer working
Jeff McKenna
jmckenna at gatewaygeomatics.com
Fri Dec 6 07:44:40 PST 2019
I just got an error with cherry-pick ("..is a merge, missing -m
parameter") so instead I went into the branch-7-4, and checked out the
specific file from master, which brings in the changes:
git checkout origin/master mapscript/phpng/php7module.i
Then commit as usual.
I'm sure there's a fancier way, but that's how I did it manually.
-jeff
On 2019-12-06 11:35 AM, Steve Lime wrote:
> What's the proper command sequence to cherry pick from and to master? I
> don't want to screw this up.
> On Sun, Nov 24, 2019 at 7:58 AM Even Rouault <even.rouault at spatialys.com
> <mailto:even.rouault at spatialys.com>> wrote:
> Hi,
> just wanted to share this info. Affects other friend projects as well
> See https://github.com/OSGeo/PROJ/issues/1741 for a few details
> Pending a potential future resolution, the old-school backporting
> method with
> "git cherry-pick" should be applied
> Even
