[mapserver-dev] Time for a 7.2.2 release?
Stephen Woodbridge stephenwoodbridge37 at gmail.com
Thu Feb 7 19:06:26 PST 2019
Steve L,
I like what Openlayers has in the way of examples but that would be a
major undertaking so I think it is beyond the scope of things. I have
found the  Mapserver OGC pages to be very help as an example. For this
specific case of MVT tiles, a simple mapfile with the appropriate bits
commented. And for mapcache, and a sample mapcache.xml referencing the
sample mapfile should do it. I would think this could all be done on a
single page and added to the documentation.
For the mapfile, I presume you need to setup an output format, and then
there is probably some metadata that needs to be defined to tell what
properties should be included with the data. Is this on each layer? What
happens if multiple layers are requested with different geometry types?
you get back a FeatureCollection?  What does a request look like, is
this a standard WMS or WFS request? I'm guessing a WMS because that is
what mapcache expects.  A sample geojson output might be helpful. I'm
just tossing out ideas here that I think might be helpful to someone not
familiar with it and trying to make use of it.
If you want to send me some info on/off list, I will try to organize it
and put together markdown page and send that back to you.
-Steve W
On 2/6/2019 5:45 PM, Lime, Steve D (MNIT) wrote:
> I'll update the RFC. At a minimum it's missing the voting history.
> As for other documentation we’d need to create a new page I guess that would be more task-based (e.g. I want to serve vector tiles using MapServer and MapCache). We don't do much of that and perhaps we should. There really aren't any new configuration options, heck the MVT output format is built in so as long as the support is compiled in there isn't much to it. Steve, maybe you could put together an outline of what your ideal "how to" might contain?
> --Steve
> -----Original Message-----
> From: mapserver-dev [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Stephen Woodbridge
> Sent: Wednesday, February 06, 2019 9:31 AM
> To: mapserver-dev at lists.osgeo.org
> Subject: Re: [mapserver-dev] Time for a 7.2.2 release?
> It would be nice if RFC 119 on MVT Tiles was updated to indicate it is
> release. I'm not sure if there is any docs, I did go looking and the
> only thing I found was references to SteveL's github stuff, but it would
> be nice is there was an example showing how to setup mapserver and
> mapcache serving MVT Tiles.
> Thanks,
>     -Steve W
> On 2/6/2019 9:47 AM, Lime, Steve D (MNIT) wrote:
>> I had mentioned a mid-January release a while back so we’re a tad
>> late. There a couple of MVT-related bug fixes, among other things,
>> that would be nice to release. Anything folks were hoping to see included?
>> Otherwise I’ll offer a +1 for a 7.2.2 release in the next week. Jeff
>> has graciously offered to help...
>> —Steve
>> mapserver-dev mailing list
>> https://na01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fmapserver-dev&data=02%7C01%7Csteve.lime%40state.mn.us%7Cbb4470025f1749596ad908d68c4818ab%7Ceb14b04624c445198f26b89c2159828c%7C0%7C0%7C636850638610513914&sdata=AJLrc9mpMolww53CG%2BU%2FGiNrQz5EbckadcO0GbM4YSQ%3D&reserved=0
> This email has been checked for viruses by Avast antivirus software.
> https://na01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.avast.com%2Fantivirus&data=02%7C01%7Csteve.lime%40state.mn.us%7Cbb4470025f1749596ad908d68c4818ab%7Ceb14b04624c445198f26b89c2159828c%7C0%7C0%7C636850638610513914&sdata=wrXfcNHMSTf5F9GDXgALzsP1DOssRbiJDaxSjIhk2F0%3D&reserved=0
https://www.avast.com/antivirus
