[mapserver-dev] setPattern in symbolObj in PHP MapScript
Nicol Hermann
mapserver at geoworld.de
Tue Jan 22 22:29:33 PST 2019
Hello Developers
I like to follow up on my own thread.
In the meantime I am pretty sure that the PHP Mapscript documentation
at https://mapserver.org/mapscript/php/phpmapscript.html is outdated
and do not reflect the current implementation.
setPattern() is available in the styleObj.
However I have difficulties to use it there as well.
Taking the other mapscript documentations as a reference I assume
setPattern expects an int array.
If I try
$styleObj-> setPattern( array( 8, 12) );
the output of the convertToString() method is:
PATTERN
4620693217682128896.00 4622945017495814144.00
END
Another issue with the style object is to set the 'linecap' property
(also not documented):
$styleObj-> set('linecap', 'butt' );
ends up with.
LINECAP NONE
Can somebody please tell me if I am doing something wrong of if these
are bugs?
Thank you very much
Nicol
Am Freitag, den 14.12.2018, 15:51 +0100 schrieb Nicol Hermann:
> Hello Developers,
> I am unclear about the pattern support in the symbolObj of PHP
> MapScript.
> Its documented to be supported at:
> https://mapserver.org/mapscript/php/phpmapscript.html#symbolobj
> but essentially it fails with a segmentation fault when I am using
> the
> 7.3dev git master branch (PHP 7.1).
> This happens regardless if the symbol is constructed as documented
> above or as part of a symbol file.
> I wonder if it has moved to the stypeObject where also a pattern
> property exist.
> Can somebody please clarify this?
> Thanks
> Nicol
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
