[mapserver-dev] Label is coming twitch
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Jul 10 08:17:14 PDT 2019
Maybe you can add your before and after images, and layer examples, to
the MapServer wiki, by creating a new page in the section "Tips, Tricks,
and Howtos" https://github.com/mapserver/mapserver/wiki
I think your example will help others.
-jeff
On 2019-07-10 11:53 AM, Liton Rafiqzzaman wrote:
> Dear Karin,
> Thank you so much for your support. Issue is resolved. I used this below
> code.
> _FORCE FALSE_
> _MINDISTANCE 300_
> _BUFFER 4_
> *Best regards,
> *Liton Rafiqzzaman*
> Solutions Architect, IMGS
> 8 Keypoint, Rosemount Business Park, Dublin 11, D11 Y77P
> *t: *+353 1 885 3839 *m:* +353 087 6037474
> *w: **www.imgs.ie <http://www.imgs.ie/>** e:
> **lrafiqzzaman at imgs.ie <mailto:lrafiqzzaman at imgs.ie>*
> Website <http://www.imgs.ie/>– Blog <https://imgsblog.wordpress.com/>–
> Twitter <https://twitter.com/IMGS_Ireland>- LinkedIn
> <https://www.linkedin.com/company/irish-mapping-and-gis-solutions-ltd>
> Follow IMGS: *cid:image001.jpg at 01CE2556.EF2BBFC0
> <http://ie.linkedin.com/company/irish-mapping-and-gis-solutions-ltd?trk=ppro_cprof>
> cid:image002.png at 01CE2556.EF2BBFC0 <https://twitter.com/IMGS_Ireland>
> imgs-logo200px <http://www.imgs.ie/>
> PoweringLocationIntelligenceEmailSignature
> <https://www.imgs.ie/events-1/powering-location-intelligence>
> *From:*Karin Kuipers <Karin.Kuipers at kartverket.no>
> *Sent:* 09 July 2019 09:58
> *To:* Liton Rafiqzzaman <lrafiqzzaman at imgs.ie>;
> mapserver-dev at lists.osgeo.org
> *Subject:* RE: [mapserver-dev] Label is coming twitch
> Dear Liton,
> There are various things that might be happening here.
> Did you use FORCE true? (set to false see what happens)
> You can also try setting a MINDISTANCE in the Label definition.
> If that does not work: try BUFFER
> Did you define the labels in one layer? Or are you showing multiple layers?
> PRIORITY might help with that.
> See https://mapserver.org/mapfile/label.html for more information.
> Good luck,
> Karin Kuipers
> *From:*mapserver-dev <mapserver-dev-bounces at lists.osgeo.org
> <mailto:mapserver-dev-bounces at lists.osgeo.org>> *On Behalf Of *Liton
> Rafiqzzaman
> *Sent:* Tuesday, 9 July 2019 10:07
> *To:* mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>
> *Subject:* [mapserver-dev] Label is coming twitch
> Dear concern,
> I need a help to resolve this issue. Please see the screenshot label
> 11KV 0.05 (U19) coming 2 times. I’m not sure why is overlapping. It
> should come 1 time. Maximum label is okay bot some label is coming 2
> times. Could you give me any idea please . Thanks in Advance !
> *Best regards,*
> *Liton Rafiqzzaman*
> *w: www.imgs.ie <http://www.imgs.ie/> e: lrafiqzzaman at imgs.ie
> mapserver-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
