[mapserver-dev] Installing Perl MapScript...
Lime, Steve D (MNIT) steve.lime at state.mn.us
Thu May 9 22:05:59 PDT 2019
I’ve done that with the main library and binaries using the cmake install prefix, works fine. Not sure how you’d do that with a MapScript module. Changing the module name works fine in general...
Note that the install issues happen regardless of name. It might well be a cmake version issue on my end.
From: mapserver-dev <mapserver-dev-bounces at lists.osgeo.org> on behalf of Sebastiaan Couwenberg <sebastic at xs4all.nl>
Sent: Thursday, May 9, 2019 11:36:51 PM
To: mapserver-dev at lists.osgeo.org
Subject: Re: [mapserver-dev] Installing Perl MapScript...
On 5/9/19 9:55 PM, Lime, Steve D (MNIT) wrote:
> I'm on SLES 11.4... Ever tried changing the module name?
No, only a single version of the package installed.
Instead of hacking the module name, why not install them in different
locations on the filesystem (e.g. using
DESTDIR=/usr/local/mapserver6.4), or using chroots/containers/VMs.
> -----Original Message-----
> From: mapserver-dev [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Sebastiaan Couwenberg
> Sent: Thursday, May 09, 2019 2:44 PM
> On 5/9/19 9:41 PM, Lime, Steve D (MNIT) wrote:
>> Anyone else out there using Perl?
> Yes, on Linux. It has been building fine there.
Kind Regards,
Bas
 GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
mapserver-dev mailing list
https://gcc01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fmapserver-dev&data=02%7C01%7Csteve.lime%40state.mn.us%7Cb2b1ebb88a954411ef6608d6d50122c7%7Ceb14b04624c445198f26b89c2159828c%7C0%7C1%7C636930598197321960&sdata=S51Qdrwv9wiUzHYz6lKrxb2%2BPsYT60rIU0%2BxZ3pTZ7w%3D&reserved=0
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20190510/3ddf89bd/attachment.html>
