[mapserver-dev] GitHub bot to close inactive tickets
Even Rouault even.rouault at spatialys.com
Fri May 31 05:11:11 PDT 2019
On vendredi 31 mai 2019 08:03:28 CEST Jeff McKenna wrote:
> I tried to install that backporting app during the sprint for the
> project, let me know if that worked.
I see it in the available GH apps in
https://github.com/mapserver/mapserver/settings/installations
so that should work
I've just created a "backport branch-7-4" label that can be set on pull
requests done against master that need to be backported to branch-7-4.
Once the PR is merged into master, the app will try to create a pull request
against branch-7-4 by cherry-picking the commits of the initial pull request.
If there's a merge conflict, an email will be sent to warn about the
impossibility and the backport must be done manually.
Even
http://www.spatialys.com
