[mapserver-dev] GitHub bot to close inactive tickets
Andrea Aime
andrea.aime at geo-solutions.it
Fri May 31 08:06:34 PDT 2019
Oh, already battle tested, very nice, then I'll propose in GeoServer as
well, thank you!
Cheers
Andrea
On Fri, May 31, 2019 at 5:04 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> On vendredi 31 mai 2019 14:21:29 CEST Andrea Aime wrote:
> > Interesting thank you!
> > I'm curious how it will work out for you, I'll stay tuned :-D
> Already massively used by QGIS. And recently adopted by PROJ and GDAL. So
> I'd
> say you can safely go ahead with it.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Regards, Andrea Aime == GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime
@geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054
Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339
8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it
------------------------------------------------------- *Con riferimento
alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 -
Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni
circostanza inerente alla presente email (il suo contenuto, gli eventuali
allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i
destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per
errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le
sarei comunque grato se potesse darmene notizia. This email is intended
only for the person or entity to which it is addressed and may contain
information that is privileged, confidential or otherwise protected from
disclosure. We remind that - as provided by European Regulation 2016/679
“GDPR” - copying, dissemination or use of this e-mail or the information
herein by anyone other than the intended recipient is prohibited. If you
have received this email by mistake, please notify us immediately by
telephone or e-mail.*
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20190531/f37430f9/attachment.html>
