[mapserver-dev] Vagrant and master...
Steve Lime sdlime at gmail.com
Fri Nov 15 08:02:47 PST 2019
That worked for me. Think it's ok to update in master and branch-7-4?
On Thu, Nov 14, 2019 at 10:24 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> On jeudi 14 novembre 2019 10:02:35 CET Steve Lime wrote:
> > Trying to get vagrant running using master (on a MacOS box) and keep
> > running into an error in compiling Proj during provisioning, anyone run
> > into this (and know how to workaround it)? --Steve
> Steve,
> The VM memory size is defined at:
> https://github.com/mapserver/mapserver/blob/master/Vagrantfile#L10
> The default 1024 MB is probably too low. Can you try 2048 ?
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20191115/925f0699/attachment.html>
