[mapserver-dev] RFC 126: Port to PROJ 6 API
Even Rouault even.rouault at spatialys.com
Mon Oct 7 07:59:09 PDT 2019
On lundi 7 octobre 2019 16:17:52 CEST Seth G wrote:
> One last question - will it still be possible to use inline projection
> parameters as in the examples at
> https://mapserver.org/mapfile/projection.html#projections-with-mapserver ?
Yes. This is used extensively in msautotest
> If so would this avoid a call to proj.db?
This will save one call, but not all calls. This will save the call for the
projectionObj instanciation. But as soon as coordinate transformations are
involved, the DB will generally be accessed. For example if transforming
between "+proj=longlat +datum=WGS84" and "+proj=longlat +datum=NAD83", the
EPSG database contains transformations between both datums
$ projinfo -s  "+proj=longlat +datum=WGS84 +type=crs" -t "+proj=longlat
+datum=NAD83 +type=crs" --summary
Candidate operations found: 53
unknown id, axis order change (2D) + Inverse of NAD83 to WGS 84 (1) + axis
order change (2D), 4 m, North America - Canada and USA (CONUS, Alaska
mainland)
unknown id, axis order change (2D) + Inverse of NAD83 to WGS 84 (3) + axis
order change (2D), 4 m, USA - Hawaii - main islands
unknown id, axis order change (2D) + Inverse of NAD83 to WGS 84 (18) + axis
order change (2D), 1 m, USA - Florida
unknown id, axis order change (2D) + Inverse of NAD83 to WGS 84 (2) + axis
order change (2D), 8 m, USA - Alaska - Aleutian Islands
unknown id, axis order change (2D) + Inverse of NAD83 to WGS 84 (41) + axis
order change (2D), 1 m, USA - Oregon and Washington
unknown id, axis order change (2D) + Inverse of NAD83 to WGS 84 (42) + axis
order change (2D), 1 m, USA - Wisconsin
[ ... truncated ... ]
Even
http://www.spatialys.com
