[mapserver-dev] Consider a 7.4.2 release?
Even Rouault
even.rouault at spatialys.com
Mon Sep 9 09:20:35 PDT 2019
On lundi 9 septembre 2019 16:20:18 CEST Seth G wrote:
> +1 - a few performance increases and memory leaks fixed, so sounds good to
Seth, which memory leaks fix are you taking about ?
As far as I can see
(https://github.com/mapserver/mapserver/commits/branch-7-4
), there are just 3 commits in branch-7-4 since 7.4.1:
- https://github.com/mapserver/mapserver/commit/cdde556308774d734cbc8ba8afbf4753832b22e4
MSSQL2008: deal with termination '$' at end of regular expression.
- https://github.com/mapserver/mapserver/commit/5be27642a63b8ad238514244e7a58cf55bfed154
Fix Undefined symbols compile error on macOS.
- https://github.com/mapserver/mapserver/commit/e6f82e9ee9c862d31fc3112576a3feb0226a8f81
Remove MakeValid() calls as these disable spatial indexes (#5859)
If more things need to be in 7.4.2, they need to be explicitly backported.
Even
http://www.spatialys.com
