[mapserver-dev] RFC 125: Support for CONNECTIONOPTIONS in mapfiles
Lime, Steve D (MNIT)
steve.lime at state.mn.us
Mon Sep 30 15:51:43 PDT 2019
Hi Even (and all): I think the RFC looks solid. In terms of implementation I was wondering if we might consider a single OPTIONS block so that the concept (and keyword) might build some commonality across objects (for example, OUTPUTFORMAT could use this). I'd leave METADATA and VALIDATION blocks alone. So one could write:
OPTIONS
# data options
"key" "value"
# connection options
"FLATTEN_NESTED_ATTRIBUTES" "YES"
# processing options
"NATIVE_FILTER" "d=234"
END
as opposed to creating a DATAOPTIONS, CONNECTIONOPTIONS and PROCESSINGOPTIONS... That would make the mapfile syntax cleaner and keep MapScript simpler.
--Steve
-----Original Message-----
From: mapserver-dev [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Even Rouault
Sent: Monday, September 30, 2019 10:00 AM
To: mapserver-dev at lists.osgeo.org
Subject: [mapserver-dev] RFC 125: Support for CONNECTIONOPTIONS in mapfiles
As discussed a few weeks ago, I've implemented support for specifying GDAL/OGR
open options through a new Mapfile syntax
See https://mapserver.org/development/rfc/ms-rfc-125.html
Even
http://www.spatialys.com/en/home/
mapserver-dev mailing list
https://lists.osgeo.org/mailman/listinfo/mapserver-dev
