[mapserver-dev] Possible bug to be reported ?
Bruno Friedmann
bruno at ioda-net.ch
Thu Jan 23 00:22:03 PST 2020
Hi all, I would like to have your thought about a problem.
During the building process of mapserver7 on openSUSE (especially our rolling
flavor Tumbleweed).
It use for the build actually gcc9 9.2.1 and swig 4.0.1
I only build now only for python3 (version 3.7.3) the mapscript part
I've got this type of error
[ 151s] make -f mapscript/python/CMakeFiles/_pythonmapscript.dir/build.make
[ 151s] make[2]: Entering directory '/home/abuild/rpmbuild/BUILD/
mapserver-7.4.3/build'
[ 151s] [ 94%] Building C object mapscript/python/CMakeFiles/
_pythonmapscript.dir/CMakeFiles/_pythonmapscript.dir/mapscriptPYTHON_wrap.c.o
[ 151s] cd /home/abuild/rpmbuild/BUILD/mapserver-7.4.3/build/mapscript/python
&& /usr/bin/cc -D_pythonmapscript_EXPORTS -I/home/abuild/rpmbuild/BUILD/
mapserver-7.4.3/build -I/home/abuild/rpmbuild/BUILD/mapserver-7.4.3/renderec
[ 151s] /home/abuild/rpmbuild/BUILD/mapserver-7.4.3/build/mapscript/python/
CMakeFiles/_pythonmapscript.dir/mapscriptPYTHON_wrap.c: In function
'imageObj_write':
CMakeFiles/_pythonmapscript.dir/mapscriptPYTHON_wrap.c:4020:28: warning:
unused variable 'renderer' [-Wunused-variable]
[ 151s] 4020 | rendererVTableObj *renderer = NULL;
[ 151s] | ^~~~~~~~
'_wrap_CompositingFilter_filter_set':
CMakeFiles/_pythonmapscript.dir/mapscriptPYTHON_wrap.c:6617:66: error:
expected expression before ',' token
[ 151s] 6617 | if (!PyArg_ParseTuple(args,
"Oz:CompositingFilter_filter_set", , &arg2)) SWIG_fail;
[ 151s] |
'_wrap_clusterObj_region_set':
CMakeFiles/_pythonmapscript.dir/mapscriptPYTHON_wrap.c:7391:59: error:
[ 151s] 7391 | if (!PyArg_ParseTuple(args, "Oz:clusterObj_region_set", ,
&arg2)) SWIG_fail;
[ 151s] | ^
So my questions are, is somebody else have seen this (arch, fedora exp...) ?
What is the root cause (will serve as subject for the issue).
Is there a simple stupid fix (then I could try to write it, test and PR
afterwards)
Thanks for any pointer
Bruno Friedmann
GPG KEY : D5C9B751C4653227
irc: tigerfoot
