[mapserver-dev] Using area expression in label text
Tamas Szekeres szekerest at gmail.com
Thu Jul 9 13:21:17 PDT 2020
Hi Devs,
I wanted to add label text to a layer to display the computed area value in
the label. Tried using this expression:
TEXT (area([shape]))
but that calculates the area in pixel space which is useless for the
purpose. I've also tried to utilize [map_cellsize] in the expression to
convert the area to map units, but [map_cellsize] always returns 0 in this
use case.
Can anyone explain how to use area in the text expression to get correct
result?
Thanks,
Tamas
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20200709/082bc435/attachment.html>
