[mapserver-dev] MS RFC 132: Update MapScript API Docs
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Jun 1 05:15:24 PDT 2020
On 2020-05-29 5:53 p.m., Seth G wrote:
> Hi all,
> I have created an RFC to formalise the proposed changes MapScript API docs which will require edits to header files, and a new mapscript requirement for the docs build process. Please see https://github.com/mapserver/docs/pull/333
> There will be a number of related pull requests, so I'd like to make sure there is approval for these changes before continuing.
> Please also see discussions with Even at https://lists.osgeo.org/pipermail/mapserver-dev/2020-May/016191.html
> I tested briefly with Doxygen but the SWIG docstrings have already been added for most classes so would require starting from scratch. It could be useful to document the C-API and try to harmonise in the future.
> In the short-term it would be good to fix a number of outdated and missing parts of the MapScript API.
The RFC is visible at https://mapserver.org/development/rfc/ms-rfc-132.html
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://gatewaygeo.com/
