[mapserver-dev] Motion: adopt MS-RFC-123: Support for MapML output in MapServer
Daniel Morissette
dmorissette at mapgears.com
Fri Mar 27 07:33:28 PDT 2020
On 2020-03-27 10:13, Jeff McKenna wrote:
>> Daniel you committed this change into docs/branch-7-4, and the live
>> website is now running docs/branch-7-6. (which means that your commit
>> into branch-7-4 caused the website to go back to 7-4) I'll fix it
>> now, but please see my message here to all devs sent on 2020-03-23
>> Fixing now...
> cherry-picked your commit into branch-7-6
To prevent this from happening again (because it will happen again to
others, it's just too easy to miss that email about the branches in the
middle of everything else) is there any reason to not remove or disable
the line that publishes the docs to the live server in the branch-7-4
.travis.yml? I see a check on $TRAVIS_BRANCH in that line, but it
doesn't seem to do much.
Daniel Morissette
Mapgears Inc
T: +1 418-696-5056 #201
