[mapserver-dev] Writing several <MetadataURL> in WMS	GetCapabilities response
    Even Rouault
    even.rouault at spatialys.com
    Tue Mar 31 05:21:27 PDT 2020
I'm considering adding the capability to write several <MetadataURL> elements in the WMS
GetCapabilities response, since this is allowed by the WMS standard.
There was an old ticket about that:
https://github.com/mapserver/mapserver/issues/3607
I'm considering the following backward compatible syntax where a  wms_metadataurl_list
could be specified to give a list of items, that would be used as suffix for metadata keys, such
that wms_metadataurl_{item} would be the actual key radix used to fetch the _format, _type
and _href items.
As the above sentence probably doesn't make any sense, here's an example that should
hopefully make it clearer:
   wms_metadataurl_list "xml html"
   wms_metadataurl_xml_format "text/xml"
   wms_metadataurl_xml_type "TC211"
   wms_metadataurl_xml_href "http://example.com/testXML"
   wms_metadataurl_html_format "text/html"
   wms_metadataurl_html_type "TC211"
   wms_metadataurl_html_href "http://example.com/testHTML"
Thoughts ?
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20200331/3237ab48/attachment.html>
