[mapserver-dev] typedef struct versus struct in mapserver.h
Seth G
sethg at geographika.co.uk
Sun May 24 12:33:25 PDT 2020
Hi all,
While going through documenting the various objects available in MapScript I notice some objects in mapserver.h are declared:
typedef struct {
} symbolSetObj;
and some are declared:
struct styleObj{
The former has the minor benefit the class can be documented by SWIG within the struct, whereas the latter must be documented before it. Does anyone know if there is a reason for the differences?
It would be nice to have them using a consistent declaration but changing classObj to the first style breaks the code (see branch at [1]) due to redefinitions in the mapserver-api.h (which is the "public MapServer API" as described on the mailing list post [2]). Maybe best to leave alone if this API is used throughout other projects [3]? Or is there a way to easily update the public API?
Seth
[1] https://github.com/mapserver/mapserver/compare/master...geographika:classObj-typedef
[2] http://osgeo-org.1560.x6.nabble.com/RFC92-implementation-caused-breaking-changes-in-SWIG-bindings-td5043826.html
[3] https://github.com/search?q=mapserver-api.c&type=Code
web:http://geographika.co.uk
twitter: @geographika
