[mapserver-dev] Mapserver getenv crashes (+ valgrind logs)
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Fri Oct 9 00:47:23 PDT 2020
This mailing list is at least as relevant until your issue is verified to be a bug. But it is more convenient to attach dumps etc. into Github. I guess that the developers will want to know more details about your self-compiled stack than just that it consists of the latest versions.
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: mapserver-dev <mapserver-dev-bounces at lists.osgeo.org> Puolesta Henrik K
Lähetetty: perjantai 9. lokakuuta 2020 7.38
Vastaanottaja: mapserver-dev at lists.osgeo.org
Aihe: Re: [mapserver-dev] Mapserver getenv crashes (+ valgrind logs)
I guess github is more relevant for this, so posted there..
https://github.com/MapServer/MapServer/issues/6167
On Fri, Oct 09, 2020 at 07:14:19AM +0300, Henrik K wrote:
> Hello,
> We use a self-compiled stack of latest versions of mapserver (7.6.1),
> proj, gdal, geos etc. The production server is pretty busy and we see
> lots of crashing related to getenv().
> I tried running valgrind, had a hard time producing any crashes since
> it seems to relate on query speed. But with 25 concurrent connection
> flooding I managed to get few dumps too..
> (gdb) where
> #0 0x0000000008e262bd in getenv () from /lib64/libc.so.6
> #1 0x000000000753e7c1 in CPLGetConfigOption () at cpl_conv.cpp:1717
> #2 0x0000000006db696c in GTiffDataset::Finalize (this=0x1c617970) at
> geotiff.cpp:7744
> #3 0x0000000006db6f9a in GTiffDataset::~GTiffDataset
> (this=0x1c617970, __in_chrg=<optimized out>) at geotiff.cpp:7714
> #4 0x0000000006db70c9 in GTiffDataset::~GTiffDataset
> (this=0x1c617970, __in_chrg=<optimized out>) at geotiff.cpp:7711
> #5 0x0000000004f7fab1 in msGDALCleanup () at
> /home/wms/src/mapserver-7.6.1/mapgdal.c:90
> #6 0x0000000004f134b7 in msCleanup () at
> /home/wms/src/mapserver-7.6.1/maputil.c:2105
> #7 0x0000000000401554 in msCleanupOnSignal (nInData=<optimized out>)
> at /home/wms/src/mapserver-7.6.1/mapserv.c:64
> #8 <signal handler called>
> #9 0x0000000008eec61d in accept () from /lib64/libc.so.6
> #10 0x00000000052f19ea in OS_Accept () from /lib64/libfcgi.so.0
> #11 0x00000000052ef9ac in FCGX_Accept_r () from /lib64/libfcgi.so.0
> #12 0x00000000052efae5 in FCGX_Accept () from /lib64/libfcgi.so.0
> #13 0x00000000052efc6a in FCGI_Accept () from /lib64/libfcgi.so.0
> #14 0x0000000000401234 in main (argc=<optimized out>, argv=<optimized
> out>) at /home/wms/src/mapserver-7.6.1/mapserv.c:137
> I have a large package of valgrind logs if someone more experienced
> could have a look? You can download it here:
> https://drive.google.com/file/d/1wgl7CgfBhyVyKMkqlOyNoAS6IZc1CEND/view
> ?usp=sharing
> Some random examples:
> ==20510== Process terminating with default action of signal 11
> (SIGSEGV): dumping core ==20510== Access not within mapped region at address 0x24ABBAA0
> ==20510== at 0x8E262BD: getenv (in /usr/lib64/libc-2.17.so)
> ==20510== by 0x753E7C0: CPLGetConfigOption (cpl_conv.cpp:1717)
> ==20510== by 0x6DB696B: GTiffDataset::Finalize() [clone .part.500] (geotiff.cpp:7744)
> ==20510== by 0x6DB6F99: GTiffDataset::~GTiffDataset() (geotiff.cpp:7714)
> ==20510== by 0x6DB70C8: GTiffDataset::~GTiffDataset() (geotiff.cpp:7720)
> ==20510== by 0x4F7FAB0: msGDALCleanup (mapgdal.c:90)
> ==20510== by 0x4F134B6: msCleanup (maputil.c:2105)
> ==20510== by 0x401553: msCleanupOnSignal (mapserv.c:64)
> ==20510== by 0x8E233FF: ??? (in /usr/lib64/libc-2.17.so)
> ==20510== by 0x8EEC61C: ??? (in /usr/lib64/libc-2.17.so)
> ==20510== by 0x52F19E9: OS_Accept (in /usr/lib64/libfcgi.so.0.0.0)
> ==20510== by 0x52EF9AB: FCGX_Accept_r (in /usr/lib64/libfcgi.so.0.0.0)
> ==20510== 6,624 bytes in 6 blocks are definitely lost in loss record 11,010 of 11,185
> ==20510== at 0x4C29F73: malloc (vg_replace_malloc.c:309)
> ==20510== by 0x4F23C89: msRASTERLayerGetExtent (maprasterquery.c:1339)
> ==20510== by 0x4EE4D16: msLayerGetExtent (maplayer.c:558)
> ==20510== by 0x4E9E43A: msOWSGetLayerExtent (mapows.c:2370)
> ==20510== by 0x4E81A50: msDumpLayer (mapwms.c:2349)
> ==20510== by 0x4E85093: msWMSGetCapabilities (mapwms.c:3613)
> ==20510== by 0x4E8A345: msWMSDispatch (mapwms.c:5175)
> ==20510== by 0x4E9B168: msOWSDispatch (mapows.c:289)
> ==20510== by 0x4EA408C: msCGIDispatchRequest (mapservutil.c:1709)
> ==20510== by 0x4EA408C: msCGIDispatchRequest (mapservutil.c:1691)
> ==20510== by 0x401385: main (mapserv.c:283)
> ==18996== Invalid read of size 8
> ==18996== at 0x8E26298: getenv (in /usr/lib64/libc-2.17.so)
> ==18996== by 0x753E7C0: CPLGetConfigOption (cpl_conv.cpp:1717)
> ==18996== by 0x6DB696B: GTiffDataset::Finalize() [clone .part.500] (geotiff.cpp:7744)
> ==18996== by 0x6DB6F99: GTiffDataset::~GTiffDataset() (geotiff.cpp:7714)
> ==18996== by 0x6DB70C8: GTiffDataset::~GTiffDataset() (geotiff.cpp:7720)
> ==18996== by 0x4F7FAB0: msGDALCleanup (mapgdal.c:90)
> ==18996== by 0x4F134B6: msCleanup (maputil.c:2105)
> ==18996== by 0x401553: msCleanupOnSignal (mapserv.c:64)
> ==18996== by 0x8E233FF: ??? (in /usr/lib64/libc-2.17.so)
> ==18996== by 0x8EEC61C: ??? (in /usr/lib64/libc-2.17.so)
> ==18996== by 0x52F19E9: OS_Accept (in /usr/lib64/libfcgi.so.0.0.0)
> ==18996== by 0x52EF9AB: FCGX_Accept_r (in /usr/lib64/libfcgi.so.0.0.0)
> ==18996== Address 0x1718ebd0 is 0 bytes inside a block of size 480 free'd
> ==18996== at 0x4C2B06D: free (vg_replace_malloc.c:540)
> ==18996== by 0x52ED2CA: ??? (in /usr/lib64/libfcgi.so.0.0.0)
> ==18996== by 0x52EF6A3: FCGX_Free (in /usr/lib64/libfcgi.so.0.0.0)
> ==18996== by 0x52EF92E: FCGX_Accept_r (in /usr/lib64/libfcgi.so.0.0.0)
> ==18996== by 0x52EFAE4: FCGX_Accept (in /usr/lib64/libfcgi.so.0.0.0)
> ==18996== by 0x52EFC69: FCGI_Accept (in /usr/lib64/libfcgi.so.0.0.0)
> ==18996== by 0x401233: main (mapserv.c:247)
> ==18996== Block was alloc'd at
> ==18996== at 0x4C2C291: realloc (vg_replace_malloc.c:836)
> ==18996== by 0x52ED383: ??? (in /usr/lib64/libfcgi.so.0.0.0)
> ==18996== by 0x52ED9A2: ??? (in /usr/lib64/libfcgi.so.0.0.0)
> ==18996== by 0x52EFA36: FCGX_Accept_r (in /usr/lib64/libfcgi.so.0.0.0)
> ==18996== 360 bytes in 30 blocks are definitely lost in loss record 68 of 75
> ==18996== at 0x4C29F73: malloc (vg_replace_malloc.c:309)
> ==18996== by 0x4EB4F6E: msStrdup (mapstring.c:2116)
> ==18996== by 0x4EAE95C: msHTTPAuthProxySetup (maphttp.c:398)
> ==18996== by 0x4E9688B: msPrepareWMSLayerRequest (mapwmslayer.c:1252)
> ==18996== by 0x4F0CE11: msDrawMap (mapdraw.c:309)
> ==18996== by 0x4E86601: msWMSGetMap (mapwms.c:3977)
> ==18996== by 0x4E8A580: msWMSDispatch (mapwms.c:5350)
> ==18996== by 0x4E9B168: msOWSDispatch (mapows.c:289)
> ==18996== by 0x4EA408C: msCGIDispatchRequest (mapservutil.c:1709)
> ==18996== by 0x4EA408C: msCGIDispatchRequest (mapservutil.c:1691)
> ==18996== by 0x401385: main (mapserv.c:283)
> Cheers,
> Henrik
> mapserver-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
