[mapserver-dev] MapServer docs and GitHub Process
Jeff McKenna jmckenna at gatewaygeomatics.com
Mon Sep 21 17:41:15 PDT 2020
Mike here is Github's updated advice on renaming master to main:
https://github.com/github/renaming So on October 1st all newly created
repositories will default to using main, and "later this year" Github
will allow a 'seamless move' for this renaming.  I think we should wait.
  Do you agree?
Option 2 is I think we can use the documentation repository to test the
renaming, and if successful apply that to the source repository.
-jeff
On 2020-09-21 7:10 p.m., michael.smith.erdc at gmail.com wrote:
> Would this also be a good time to rename master as main?
> Mike
>> On Sep 21, 2020, at 4:23 PM, Jeff McKenna <jmckenna at gatewaygeomatics.com> wrote:
>> Hi Seth,
>> Thanks for mentioning this.  Indeed about 6 months ago I set up the backport bot for the documentation, but I didn't seem to pull the final trigger (this is usually a sign that I had hit a wall).
>> I've gone through and configured the backport bot for the documentation as well now (had a few failures but it's fixed now).
>> Some other points:
>> - updated Github settings so that 'master' is now default branch for documentation, and changed the message to say to submit PRs to master
>> - I also took this time to finally change our old "docs" repository name (this goes way back to our CVS days) to something more meaningful: "MapServer-documentation".  Github handles the appropriate redirects. (https://github.com/MapServer/MapServer-documentation)
>> - did the same for our "mapserver" Github organization, so that it is now "MapServer" (https://github.com/MapServer)
>> - I've enabled that Github action 'check-crlf' for the documentation workflow, and changed all remaining CRLF linefeeds in the documentation files, to LF.  Now, when you submit a PR or a push, this checks the entire repository for any CRLF linefeeds, and reports a list of files with problems, or states "no files with CRLF endings found"
>> - also added the git settings that I use locally, to convert to LF before commit, to our documentation guide, and made a note of this LF requirement (see third point at https://mapserver.org/development/documentation.html#github-notes ). But this new Github action will nicely tell us about the linefeed problem, thanks Seth for mentioning it!
>> - regarding the source code directory, I also tried to enable the check-crlf, and it found a surprising number of source code files with non-LF, but for it to work we'll have to ignore some directories and filetypes (such as msautotest, pdfs, etc).  There is also a PR for check-crlf that adds this, and once that is accepted I'll add this into the main source repository as well.
>> In summary, we can now use the 'backport branch-7-6' label for documentation, and, all pull requests should now we made to master.  All documentation pull requests are now checked for linefeeds, and a build error is thrown if CRLF are found.
>> Let me know if any other changes need to be made.
>> thanks!
>> -jeff
>> Jeff McKenna
>> MapServer Consulting and Training Services
>> co-founder of FOSS4G
>> http://gatewaygeo.com/
>>> On 2020-09-19 6:38 p.m., Seth G wrote:
>>> Hi all,
>>> At the moment pull requests to https://github.com/mapserver/docs/ should be made to the latest active branch (currently 7.6). Documentation for new features however should be made to master (as they won't apply to new features).
>>> Sometimes it is difficult to know if a code change will be backported or not.
>>> There are several pull requests that have been added to the 7.6 branch that are not in master, and some in master that are not in 7.6. I'm not sure how these possible conflicts are merged following a release (likely a painstaking manual process by Jeff?).
>>> Would it make sense to follow the same development process as the MapServer codebase, and set up the GitHub "backport" bot? Then if code is backported the doc pull request can be too, and master will contain all updates.
>>> Seth
>>> web:http://geographika.co.uk
>>> twitter: @geographika
