[mapserver-dev] mapscriptng - classes all lower case?
Jeff McKenna jmckenna at gatewaygeomatics.com
Thu Apr 29 15:03:47 PDT 2021
Please follow the migration steps at:
https://mapserver.org/MIGRATION_GUIDE.html#mapserver-7-2-to-7-4-migration
Wishing you a nice weekend,
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
On 2021-04-29 6:54 p.m., Worth Lutz wrote:
> Jeff,
> I found that file in /usr/lib64/php/modules along with php_mapscriptng.so.
> It was using the same 4.0.1 SWIG.  The classes described there use
> camelCase and not lowercase.
> I'll look for more clues.
> *Worth Lutz*
> On 4/29/2021 4:00 PM, Jeff McKenna wrote:
>> At the top of that file (around line 5) it should state what version
>> of SWIG that was used to generate that file: in my case, for the
>> Ubuntu server that I am checking, it is: 4.0.1  (MS4W uses
>> master/4.1.0-dev)
>> -jeff
>> On 2021-04-29 4:46 p.m., Jeff McKenna wrote:
>>> I have not seen that case before.  Once installed, you should find
>>> the associated file (containing the MapServer constants and classes)
>>> in a path something like:
>>>    /usr/lib/php/xxx/mapscript.php
>>> If you are using today's 'main' checkout, line ~2479 of mapscript.php
>>> should list the "class mapObj" definition.
>>> My servers are mostly Ubuntu, so I am not sure about RHEL8.
>>> -jeff
