[mapserver-dev] Motion: rename default 'master' branch to 'main'
Tom Kralidis tomkralidis at gmail.com
Wed Jan 13 03:27:21 PST 2021
+1
..Tom
On Wed, Jan 13, 2021 at 6:08 AM Rahkonen Jukka (MML)
<jukka.rahkonen at maanmittauslaitos.fi> wrote:
> +1
> -Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: mapserver-dev <mapserver-dev-bounces at lists.osgeo.org> Puolesta Jeff McKenna
> Lähetetty: tiistai 12. tammikuuta 2021 22.54
> Vastaanottaja: 'MapServer Dev Mailing List' <mapserver-dev at lists.osgeo.org>
> Aihe: [mapserver-dev] Motion: rename default 'master' branch to 'main'
> Hi PSC,
> Some may remember a past discussion here about possibly renaming our 'master' branch to a less insensitive name as 'main'.  It was decided to wait a bit, as Github stated that by January 2021 it would make it easier to change the default branch name (https://github.com/github/renaming).
> I have checked our settings today and indeed it is now possible through the regular settings.
> For our code repository, 'MapServer', here is the dialog window before pressing the 'rename branch' button: https://pasteboard.co/JJlr3xy.png
> For those not wanting to click an external link, it states that Github will automatically:
> - update 8 pull requests targeting this branch across 6 repositories
> - update 1 branch protection rule that explicitly targets 'master'
> *note that renaming this branch will not update your members' local environments
> For our documentation repository, 'MapServer-documentation', here is the dialog window before pressing the 'rename branch' button:
> https://pasteboard.co/JJluDt6.png
> As you can see the impacts on the documentation are less because there are no open pull requests etc.
> So, it is a good time to move forward with this.  Could there be some other impacts?  Possibly, but I believe it is worth trying now, and we can adapt if necessary.
> I motion to rename the default 'master' branch to 'main' for the MapServer and MapServer-documentation repositories.
> I'll start with a +1
> PS. happy 2021 to everyone
> -jeff
> mapserver-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
