[mapserver-dev] Version 8.0, more opt in and less opt out...
    Steve Lime
    sdlime at gmail.com
    Mon Jun 14 07:46:47 PDT 2021
Thinking about this, I'd guess I'd propose adding a mutable parameter to
structures that support runtime updates. It wouldn't be a boolean but
rather a string. Default would be NULL so everything is immutable by
default. If a value is present the value would be interpreted as a
case-insensitive regex against the allowed attributes. So, for example you
could have:
SCALEBAR
  MUTABLE "UNITS"
END
So, in this case the units of scalebar could be changed via the syntax
given in RFC 44 but nothing else.
--Steve
On Tue, May 18, 2021 at 8:51 AM Steve Lime <sdlime at gmail.com> wrote:
> Thanks for the explanation Dan! FWIW I can work up a pull request to
> illustrate what I was thinking by adding a mutable parameter... I think
> that can be a simple, easy to understand and explicit approach. --Steve
> On Tue, May 18, 2021 at 8:47 AM Daniel Morissette <
> dmorissette at mapgears.com> wrote:
>> FYI mode=OWS was added to deal with OGC compliance testing which
>> requires the server to produce an exception in some cases if the
>> SERVICE/REQUEST parameters are missing... and since MapServer falls back
>> on the CGI mode by default if SERVICE/REQUESTS are not present then the
>> only way we could imagine to produce that exception and be compliant was
>> to add a mode=OWS vendor-specific param in the onlineresource.  More
>> info here:
>> https://github.com/MapServer/MapServer/issues/2512
>> and
>> https://github.com/MapServer/MapServer/issues/2531
>> P.S. I'm following this thread and think it may be a good idea to have
>> "more opt in and less opt out" for security reasons as long as the
>> mechanism to handle this is clear and easy to understand, but I don't
>> have a strong opinion on the proposed changes, that's why I'm staying
>> quiet.
>> Daniel Morissette
>> Mapgears Inc
>> T: +1 418-696-5056 #201
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20210614/f8a506a0/attachment.html>
