[mapserver-dev] Querymap fails for polygon layers with labels only (no styles)
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu Mar 11 14:52:35 PST 2021
Hi Tamas,
Good catch, I don't think I've ever tried that case with a polygon,
querymap with STYLE HILITE, and layer with only label. I think that
would be a good enhancement. Would you mind also creating a test
mapfile for this in msautotest as well?
thanks,
-jeff
On 2021-03-11 5:41 p.m., Tamas Szekeres wrote:
> Hi Devs,
> Currenly msDrawQueryLayer fails with error if the layer type is polygon,
> the querymap style is MS_HILITE, and the layer class contains only label
> elements.
> Is this intentional?
> The same setting works with the point layers (where the labels are being
> highlighted) so I guess it should also work with the polygon layers.
> The corresponding code looks like this:
> /if(layer->type == MS_LAYER_POLYGON) { /* alter BOTTOM style since
> that's almost always the fill */
> if (layer->class[i]->styles == NULL) {
> msSetError(MS_MISCERR, "Don't know how to draw class %s of
> layer %s without a style definition.", "msDrawQueryLayer()",
> layer->class[i]->name, layer->name);
> msFree(colorbuffer);
> msFree(mindistancebuffer);
> return(MS_FAILURE);
> however the classes with no styles can surely be handled later in the code:
> } else if (layer->class[i]->numlabels > 0) {
> colorbuffer[i] = layer->class[i]->labels[0]->color;
> layer->class[i]->labels[0]->color = map->querymap.color;
> Should I prepare a fix for this problem?
> Best regards,
> Tamas
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
