[mapserver-dev] Versioned MapServer Docs?
Jeff McKenna jmckenna at gatewaygeomatics.com
Thu Mar 18 14:18:38 PDT 2021
Ah ok Even, your words sunk into me more now, good points.  Although I
differ in that I think keeping all of the 'versionadded' references are
very important, as this is the rich information that is so priceless
(knowing when exactly something was added) for both the users and
maintainers of the software/docs.  I personally have been making sure to
add those 'versionadded' and 'deprecated since' and 'since version'
notes into the docs, as this information is so useful to users, even in
the case of it being added in 5.0 etc.  And as you said, I have to go
get that information in the RFC, which users won't know to check, so
I've been adding those 'since version' references that you mention, to
help users.
-jeff
On 2021-03-18 5:39 p.m., Even Rouault wrote:
> If we keep a single version for simplicity, we could however decide to
> clean up a bit the doc content to remove mentions of outdated versions
> to avoid cluttering it. There is little point in mentioning any version
> older than let's say 5? years ago. I've done that a bit in the GDAL docs
> a few months ago, removing any mention of GDAL < 2, considering that all
> people looking at the docs would have at least GDAL 2.x something
> available, or if they use antiquated stuff, too bad for them.
> Looking a bit at download artifacts, for MapServer we could decide for
> example that the baseline is MapServer 6.4 (or possibly even 7.0 for
> simplicity), and remove any mention of that or older versions (except in
> RFCs that are reflective of history)
> "grep -r versionadded en" in the doc repository shows a number of things
> of the 4.x, 5.x or early 6.x eras.  'grep -ri "since version" en' shows
> also a number of potential cleanups.
> Even
> Le 18/03/2021 à 21:15, Jeff McKenna a écrit :
>> My preference has always been for Option#1, as it is much easier to
>> maintain in my experience, as it is stated clearly as deprecated at
>> the parameter level in the document.
>> Speaking openly here, if I was paid fulltime to manage the docs and
>> all the different build versions of the docs, and publishing them
>> online, I could see how that would be possible; but as we are made up
>> of volunteers, I would prefer to keep the single version updated with
>> references to when the feature was added (what MapServer version), and
>> if it is deprecated.  I remember recently spending much effort on that
>> in-line versioning improvements, I think that is working nicely now.
>> -jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
