[mapserver-dev] mapfile.dtd and mapfile.xsd
Jeff McKenna
jmckenna at gatewaygeomatics.com
Sun May 2 06:32:03 PDT 2021
I would give the community a full 7 days to respond, and if no response
(response being a volunteer to maintain the file) remove it from the
repository (it can always be restored later by a champion). -jeff
On 2021-05-02 10:05 a.m., Steve Lime wrote:
> IMHO if we're not going to maintain it we might as well remove it.
> Someone more knowledgeable than I regarding XML might make the case for
> maintaining both. --Steve
> On Sun, May 2, 2021 at 4:36 AM Seth G <sethg at geographika.co.uk
> <mailto:sethg at geographika.co.uk>> wrote:
> __
> Thanks Steve, I won't try and keep this updated.
> Is the preference to remove the file completely or to add a comment
> indicating it is no longer maintained?
> I've posted to the user list to try and gauge the level of XML usage.
> Seth
> web:http://geographika.co.uk <http://geographika.co.uk>
> twitter: @geographika
> On Sat, May 1, 2021, at 9:56 PM, Steve Lime wrote:
>> I didn’t answer your question though and would agree with you that
>> we don’t need the dtd.
>> On Sat, May 1, 2021 at 8:22 AM Steve Lime <sdlime at gmail.com
>> <mailto:sdlime at gmail.com>> wrote:
>> I'm curious if XML mapfiles are used much at all regardless.
>> Would be curious to hear from those users.
>> On Sat, May 1, 2021 at 5:04 AM Seth G <sethg at geographika.co.uk
>> Hi all,
>> As part of the Mapfile syntax clean-up in RFC133 there are
>> a couple of files that contain lists of keywords:
>> - mapfile.dtd - only a couple of updates in the last 20
>> years [2]
>> - xmlmapfile/mapfile.xsd - several updates to keep in sync
>> with Mapfle keywords [3]
>> Any thoughts/preferences on what to do with these?
>> I'd propose to remove mapfile.dtd (I'm unsure if it is
>> still used), and update mapfile.xsd with the syntax
>> changes. There are other new keywords missing in
>> mapfile.xsd that can be addressed separately.
>> Seth
>> [1] https://mapserver.org/development/rfc/ms-rfc-133.html
>> <https://mapserver.org/development/rfc/ms-rfc-133.html>
>> [2]
>> https://github.com/MapServer/MapServer/commits/main/mapfile.dtd
>> <https://github.com/MapServer/MapServer/commits/main/mapfile.dtd>
>> [3]
>> https://github.com/MapServer/MapServer/commits/main/xmlmapfile/mapfile.xsd
>> <https://github.com/MapServer/MapServer/commits/main/xmlmapfile/mapfile.xsd>
