[mapserver-dev] WMST Get Capabilities opens OpenLayerViewer
Bruce Clay
bclay1297 at gmail.com
Tue Nov 16 09:26:09 PST 2021
Jukka:
Yes I am trying to time sequence weather images from a mapserver time
enabled layer
Bruce
On Tue, Nov 16, 2021 at 11:53 AM Rahkonen Jukka (MML) <
jukka.rahkonen at maanmittauslaitos.fi> wrote:
> Hi,
> WMTS means Web Map Tile Service and you can find the standard from here
> https://www.ogc.org/standards/wmts. WMS-T is time enabled Web Map
> Service (WMS) and how to use the time dimension is documented in WMS
> standards https://www.ogc.org/standards/wms. Are you interested in tiles
> or times?
> -Jukka Rahkonen-
> *Lähettäjä:* Bruce Clay <bclay1297 at gmail.com>
> *Lähetetty:* tiistai 16. marraskuuta 2021 18.46
> *Vastaanottaja:* Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi
> *Kopio:* MapServer Dev Mailing List <mapserver-dev at lists.osgeo.org>
> *Aihe:* Re: [mapserver-dev] WMST Get Capabilities opens OpenLayerViewer
> Jukka:
> Your email got me thinking so I took the t off and made it a regular WMS
> query and I can get an image. It looks like the WMS-T is just a WMS with a
> time field, not a protocol that will sequence the images.. So it looks
> like what we might need to do is a postgis select with a time window or at
> least starting point then make separate queries to get the actual images.
> Does that sound right?
> QGIS has a TimeManager plugin but it is updating the time display but not
> showing the images. That is a different issue for a different forum.
> Thanks
> Bruce
> On Tue, Nov 16, 2021 at 9:42 AM Rahkonen Jukka (MML) <
> Hi,
> Mapserver-users list is where users can ask questions and give answers.
> There is no reason to believe that Mapserver supports WMTS at all
> https://www.mapserver.org/documentation.html#ogc.
> Also in the query you used &SERVICE=WMST&version=1.1.1. “WMST” must be a
> typo and WMTS has only one published version 1.0.0. The error message from
> Mapserver is not especially bright, Geoservers do that better.
> https://demo.geo-solutions.it/geoserver/ows?service=WMTS&version=1.0.0&request=GetCapabilities
> Result:
> <ows:Exception exceptionCode="InvalidParameterValue" locator="service">
> <ows:ExceptionText>No service: ( WMTS )</ows:ExceptionText>
> </ows:Exception>
> You must install MapCache and configure it to use Mapserver as a WMS
> source. MapCache can do WMTS.
> -Jukka Rahkonen-
> *Lähettäjä:* MapServer-dev <mapserver-dev-bounces at lists.osgeo.org> *Puolesta
> *Bruce Clay
> *Lähetetty:* tiistai 16. marraskuuta 2021 14.38
> *Vastaanottaja:* MapServer Dev Mailing List <mapserver-dev at lists.osgeo.org
> *Aihe:* [mapserver-dev] WMST Get Capabilities opens OpenLayerViewer
> I am using the mapserver from the latest MS4w. When I query WFS and WMS
> GetCapabilities I get a normal xml reply. When I do a WMST
> GetCapabilities on the same server the OpenLayersViewer opens but is
> empty. Viewing the web page source reveals java script but no xml
> information.
> The query follows
> http://localhost/cgi-bin/mapserv.exe?map=/data/config/map/nasaww.map&SERVICE=WMST&VERSION=1.1.1&REQUEST=GetCapabilities
> Bruce
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20211116/d264d782/attachment.html>
More information about the MapServer-dev
